Changing gear oil
  • 3693 Views
Offline MB
  • 223
Changing gear oil
« on: January 24, 2004, 08:44:33 AM »
Just thought I'd post this lil tip for changing the gear oil in the diffs, tran, and transfer. First thing I just learned today....the hard way! :-[
1: Make SUREyou can remove the fill plugs first!
I changed the gear lube in the front diff first, no problems. Moving back to the trans I made the mistake of pulling the drain first then played hell getting the fill plug to break loose. Now what do I do? The gear lube is all gone and no way of re-filling.... But with lots of grunting and cussing it finally came out! All is well now. :)
2: Auto Zone sell a neat lil hand pump that attaches right to the top of the 1 gal. jug of gear lube, handy lil item no mess no waste.
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: Changing gear oil
« Reply #1 on: January 24, 2004, 08:58:27 AM »
THAT IS A GOOD BIT OF ADVICE.....ESP. TO US VERY NOVICE WRENCHERS.....THANKS FOR SHARING...I KNOW EVERYDAY FROM READING ALL THE POSTS I LEARN SOMETHING TO ADD TO THE BACK OF MIND FOR FUTURE REFFERANCE.....ERIC, WE NEED A THUMBS UP SYMBOL UP THERE IN THE SMILEYS.. :P
« Reply #2 on: January 24, 2004, 09:09:30 AM »
You could of checked the amount that the trans takes and then pulled the shifter out and poured it in there ;D same goes for the x-fer case in a pinch, and it is some times easyer :-*
Offline MB
  • 223
« Reply #3 on: January 24, 2004, 09:18:58 AM »
Thats right! Man if I could just stop and think when I'm getting flustered  :-[
Oh well water under the bridge now, but thanks for the reminder will write that in my note section in the Haynes.
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #4 on: January 24, 2004, 09:36:22 AM »
I had my mechanic do that for me, since there is no way I can get under my Sidekick to do that sort of thing.
Offline Speedracer7c
  • 2210
« Reply #5 on: January 24, 2004, 01:33:40 PM »
I can get under mine with a floor jack and jack stands....haahha thats how i do everything...and i have a dirt floor in my garage let me tell you its not fun!
Offline trackinstile
  • 435
« Reply #6 on: January 24, 2004, 08:10:00 PM »
Unfortunately I don't even have a garage, and my driveway is a hill, as you can imagine, it gets pretty interesting out there.  Fortunately I work for a gas staion part time, and the guy is really great about weekends and personal vehicles, and if I don't have th etime he helps me out.  Without that though, I'd be stuck.
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #7 on: January 25, 2004, 12:36:46 AM »
Yeah I can get under mine pretty good to inspect the exhaust system and some cleaning around...but other then that, it's off to the shop.  If I had a heavy duty hoist and a taller garage...I'd be set! ;D
« Last Edit: January 25, 2004, 12:37:19 AM by In_Flames »
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #8 on: January 25, 2004, 09:05:37 AM »
You can't do that with a Side/kick trans.  The shifter is remote, meaning that the shifter is extended back about 5-6".  If you tried to fill it that way you'd get a big mess on the floor.
You could do it on the T-case but I'd be slow going because I think the path the oil would take is the same path as the vent hole.  Like trying to get kectup out of the bottle.
32 MTR's Warn 8000i
