Quarter Elliptical not streetable
  • 19 Replies
  • 8522 Views
Offline 1bigtracker
  • 3409
Re: Quarter Elliptical not streetable
« Reply #15 on: January 18, 2004, 08:11:16 AM »
i was going to say that but then...
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
« Reply #16 on: January 22, 2004, 09:30:27 AM »
and whats the diff between 3/4 Elliptical Rear Suspension and 1/4 Elliptical Rear Suspension?
The main difference is how much of the original donor spring you use.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline 1bigtracker
  • 3409
« Reply #17 on: January 22, 2004, 11:12:00 AM »
thanks 87BlackSami for all the info.
Stu
Offline TinTopper
  • 73
  • 1987.
    • dayid.org
« Reply #18 on: January 24, 2004, 03:03:41 AM »
That, and a 1/4 elliptical has the pack attached in front of the axle, with the single attached to the axle, whereas a 3/4 has an entire standard spring-setup, except the rear eyelet of the spring, instead of being attached to a shackle, is attached to the eyelet of another 1/4 pack, that then runs and attaches almost directly above the tire...
Also look into buggy-springs (full elliptical)
Here's some nice little tech-talk from another board I'm on about the differences in elliptical spring setups.
http://www.pavementsucks.com/forums/viewtopic.php?topic=23880&forum=16&highlight=buggy+spring
As for the original topic, 1/4 elliptical is EXTREMELY streetable, it is a standard 4-link setup, nothing weight about it, just using leaves instead of coils, and YES, leafs have their advantages over coils.
I would never run a 1/4-elliptical front though, just becuse the geometrics of how it works wouldn't be too great for a front-end.
« Last Edit: January 24, 2004, 03:07:44 AM by vocabulaic »
'87 TinTop
'04 F-150
Offline 1bigtracker
  • 3409
« Reply #19 on: January 24, 2004, 03:15:17 AM »
no i wasn't going to go Quarter Elliptical on the front.  just didnt think it wouild work well.
Stu
  ÂÂÂÂÂÂÂ
