Quarter Elliptical not streetable
  • 19 Replies
  • 8224 Views
Offline 1bigtracker
  • 3409
« on: January 17, 2004, 02:38:34 AM »
i was just reading on RRO and it said that Quarter Elliptical Rear Suspension is not made for street use.  i never knew that.  i was going to go Quarter Elliptical on the rear of a truck but i can't now of that.  do you think i could get by with sway bars with dissconects(spell check)?  lata stu     http://www.rocky-road.com/quarterelliptic.html
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Quarter Elliptical not streetable
« Reply #1 on: January 17, 2004, 04:29:32 AM »
Are you looking to put one on your tracker?
32 MTR's Warn 8000i
Offline 1bigtracker
  • 3409
« Reply #2 on: January 17, 2004, 05:00:49 AM »
no not on my tracker.  i was looking into getting my friend a yota P/U or 4 runner and was going to put a solid front axle in with a coiled 4 link and rear Quarter Elliptical.
« Reply #3 on: January 17, 2004, 05:33:21 AM »
just put in a rear four link  also and paint it black ! and some good shocks for the street, maybe an extra pair that can be removed for off road!
« Reply #4 on: January 17, 2004, 05:57:32 AM »
Why go quarters when coils are the trick
setup??? get a nice 4 link going and coils.
It will be more roadable and better flex than
with half a leaf spring, which is what quarters are.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #5 on: January 17, 2004, 05:58:36 AM »
Dont know on what yet, but I want one
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #6 on: January 17, 2004, 06:42:16 AM »
I'm with wildgoody.  4 link with coils.
32 MTR's Warn 8000i
Offline 1bigtracker
  • 3409
« Reply #7 on: January 17, 2004, 07:55:28 AM »
cuz their is only 1 truck the has Quarter Elliptical rear set up around here and hes not in my 4WD club.  i just wana do somthing diffent.  i dunno, i might just keep leafs all the way around.  lata stu
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #8 on: January 17, 2004, 08:47:56 AM »
About the road thing.  Most police only know "it can't be this tall" or "you tires stick out too far".
If you feel its safe and it drives ok, go for it.  We had a guy in our club (a jeep) that ran one for a year.  He know has the whole truck torn down and is making a moster of a truck out of it.  I think it will still have the 1/4 elliptical when he's done.
32 MTR's Warn 8000i
Offline Yankee Tim
  • 431
  • Who says a GV is a grocery getter?
    • Yankee Off-Road
« Reply #9 on: January 18, 2004, 02:04:38 AM »
Not exactly.
A proper 1/4 elip is a very, very trick setup, and without some on the issues that appear in a 4-link coil.
As far as "not suitale for road use".  This is a common disclaimer.  Most 4x4 vendors recommended their lifts for off-highway use only.  The 1/4 elip that RRO sells is made by Spidertrax.  They don't recommend they QERS (as they call it) for road use.  Liability is the reason.
Now, a QERS is technically a 4link using leafs instead of coils.  This has benefits.  For one, coils are designed to be compressed or stretched, but not both.  All of the Sammy coil kits ridigly mount the coils and both ends, don't run bumpstops and both overcompress the coils and use them as limiting straps for droop.  Over time, this will toast a coil.
A leaf spring is designed to flex in both directions, to a point.  The Spidertrax QERS incorporates adjustable bumpstops as well as limiting straps.  This keeps the springs nice-nice and elimitates bind.
I've seen several of these rigs run, and they do awesome.  The flex from a QERS and a coily are equal.
The benefits of coils are they are cheaper than custom-designed and built 1/4 leaf packs.
The best route wouldn't be a 4-link with coils or 1/4s, but Coil-Overs.  Period.
Yankee Tim
Offline 1bigtracker
  • 3409
« Reply #10 on: January 18, 2004, 02:22:23 AM »
coil overs make me drool but $$$.    i love them.    but could i just cut any set of rear springs in half of the Quarter Elliptical?  lata stu
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
« Reply #11 on: January 18, 2004, 07:20:42 AM »
STU
Your going to want a donor leaf of the same width. Also I would recommend strongly to run a panhard bar across the back to keep the rear centered.
Check this out. ;D
http://www.off-road.com/jeep/tech/susp/elliptical.html
Alot of good info.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline 1bigtracker
  • 3409
« Reply #12 on: January 18, 2004, 07:27:28 AM »
wow i thought that you had to use a 4 link or 3 link when doing that.  and yes a panhard bar will be in there too.  lata stu
Offline 1bigtracker
  • 3409
« Reply #13 on: January 18, 2004, 07:29:25 AM »
and whats the diff between 3/4 Elliptical Rear Suspension and 1/4 Elliptical Rear Suspension?
Offline zooky
  • 135
« Reply #14 on: January 18, 2004, 07:34:14 AM »
about 1/2 an elliptic ;D
