everyones mods
  • 47 Replies
  • 16756 Views
0 Members and 12 Guests are viewing this topic.
Crabzuki
Re: everyones mods
« Reply #30 on: December 20, 2003, 02:14:22 AM »
1989 Suzuki Sidekick 2dr HT with 2,565 original miles
Full competition port and polish with 1.6 Suzuki valves:
  * New valves
    * Iskendarian cam (266 duration, 330 lift)
    * Forged Pistons
    * Hawk Dual Intake Manifold
    * 2 Weber 40mm Sidedraft Carburetors
    * CALMINI Tri-Y Design Header
    * CALMINI 2" Diameter Cat-Back Exhaust
    * Adjustable Cam Sprocket (8valve)
    * Axcel Ignition
    * Summit Fuel Cell
    * External Summit Fuel Pump
    * 2002 Ford Ambulance Altenator
    * Altima Spiral Cell Blue Top Battery
    * Corbeau Race Seats
    * Custom Diamond Plate Interior
    * Billet Gages
    * Billet Transfer Case Shifter
    * Sony AM/FM Cassette
    * Sony 10 Disk CD Changer
    * Sony 300 Watt Amp
    * 2 Sony 5 inch speakers in dash
    * 2 Sony 6x9 Speakers
    * 2 Sony 12 inch Sub-woofers
    * Comp Explorer Pre-Runner Bumper
    * 2 (6 inch) KC 150 Watt Lights
    * 5 (8.5 inch) Bead Locks
    * 5 (255/70R15) Firestones
    * Calmini Interior Roll-Cage
    * Billet Rearview Mirror
    * Billet Window Cranks
    * NOS With Dual Fogger Plates
Also custom aerodynamic wrinkled sheet metal roof, and oak tree sheet metal tear on one side, and gravel stimpled design on the other side.
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
Re: everyones mods
« Reply #31 on: December 20, 2003, 05:13:25 AM »
Mostly Stock:
1991 Suzuki Sidekick JA
8V - AT - 4x4
Wheels:
Stock Steel Circle Hole Rims
Tires:
Front: BF Goodrich Control TA
Rear:  BF Goodrich Trail Blazer II
Engine:
K&N Stock Airbox High Flow Filter
K&N Gold Oil Filter HP-1002
Mobil 1 5W-30 Motor Oil
Bosch Platinum Spark Plugs
Audio:
Kenwood KDC-217s CD player
Speakers:
Front: 4" Kenwood KFC-1077  90 watts
Back:  6x9" Pioneer TS-A698OR 350 watts
And that's it.
What I want:
Another set of rims, preferably stock Suzuki aluminums with the tires I have now slapped on so I can put some winter tires on my steel rims.
CALMINI performance Exhaust System
High intensity Fog Lamps
Bush Bar
And that's about it for now.
Offline CrazyCooter
  • 20
Re: everyones mods
« Reply #32 on: December 26, 2003, 12:51:36 PM »
92 Samurai
Engine:
1.3l .040 over
Sumo2 head
Adjustable cam gear
Assy. underdrive pulley
Thorley header w/ 2.25" pipe, 2 chamber Flowmaster
Custom cold air intake
Flywheel lightened 1.5lbs.
Drivetrain:
32x10.50 TSL Radials on 15x10 3" BS Chrome Blades
Stock trans. .865 5th
4.16 Calmini T-case
Narrowed Toyota rear diff. w/ Detriot Tru-Trac and 4.56's
Stock front w/ 4.57's and SKY Axle Truss
Toyota CV shaft in rear
Suspension and Steering:
Breeze 5.5" SPOA
Rancho 9000's at all 4 corners
Breeze ladder bar
1.5" Shackles
OTT Steering linkage
Kick' power steering
Other stuff:
Alpine CD
Pioneer amps
MB Quart Highs
Bass shakers
KC's mounted the winshield tabs
Aluminum channel front bumper
Bestop Sunport Top
Radio Shaft CB
Turbo Comming Soon!
Offline ox13
  • 18
Re: everyones mods
« Reply #33 on: December 26, 2003, 03:09:04 PM »
Well here is my list
1987 suzuki samurai
custom coil suspension
1.3 L
front axle is a suzuki with a lock rite in it 3.73 gears
rear axle is a suzuki  with a welded diff and custom disc brakes 3.73 gears
running 33x12.5x15 TSL's
front rims are black rock crawlers 15x10
rear rims are custom made bead locks 15x9
duel t-case's front one has a GRS II gear set second one is stock gears
toyota power steering
full cage
warn 6000 lb winch with winch rope
full cage
summit racing seats
RCI harness
5 gallon sumit racing fuel cell
and a lot of dents and cut sheet metal.
now the mods being done to it over the winter months are as follows
79 dodge ramchager axles
front is a D-44 with a lock rite and 4.10 gears
rear is a dodge 9.25 welded with 4.10 gears and disc brakes
Moving up to 36x14.50x15 ground hawgs
on 15x8 rims
I changing my winch mount and that is it for this year
« Last Edit: December 26, 2003, 03:11:08 PM by ox13 »
Offline bhaugen
  • 140
Re: everyones mods
« Reply #34 on: December 26, 2003, 05:32:33 PM »
Here goes My rig
87 sammy
-Stock motor and tranny.
-Weber Carb.
-GRS 2 transfer case (4.89:1)
-5.5" SPOA
-Lockright lockers f/r
-Just completed swapping Rear spring with the fronts  w/ 4" Shackles, and added 5" shackles to rear to level.
-31x10.5 Brigstone Dueller MT's
-Custom front bumper
To Do this winter yet.
-replace front seats
-finish half doors from doors off of wrecked sammy. learning how to weld sheet metal.
-pumpkin caps. Got enough dents in them already.
Offline Kreg
  • 795
    • Island 4x4
Re: everyones mods
« Reply #35 on: December 27, 2003, 05:36:42 AM »
92 Tracker...
- Calmini 3" body lift
- Calmini 3" Suspension lift
- American racing black steel rims (15x7)
- 31" BFG mudders
- Calmini Header and 2" exhaust
- Rear Lockright locker.
- K&N air filter
- Calmini steering Stabilizer
TO come...
- CB and Whip
- Calmini Anvil
- Calmini transfer case gears
Offline Z3bra
  • 273
Re: everyones mods
« Reply #36 on: December 27, 2003, 06:56:09 AM »
Mine's nothing too impressive yet. But here it is:
1990 Tracker LSi  Black with red accent trim from the factory and the lovely factory orange/yellow/red seat center sections. (nasty lookin color scheme all in all on the inside when the rest of the interior is gray)
Under the hood:
Engine: 1993 Sidekick 1.6 8v.  *(scroll down)
When putting the new engine in, I did the following to it.
.030 over pistons.  Just the boring kind. Nothing fancy.
.020 milled off the head
Head and intake manifold matched to port openings on the gaskets courtesy of our friends at Dremel and way too much of my time spent in the garage.
Hawk Suzuki "Torquer" regrind cam. (heard it's actually an Isky cam but dunno for sure, not a bad improvement though really)
Calmini header and 2" mandrel bent exhaust, 2.5" catco catalyst off a toyota supra.  It was almost new and my friend was just gonna pitch it anyway since it wouldn't really work too good with his 3" exhaust.
Magnaflow 2" straight through oval muffler.
Transmission: New pan seal and filter! on the good old 3 speed automatic.  Good for at least 30  or 40 horsepwer there I'm sure.  If I could find some stickers to advertise the filter and gasket that's probably good for another 10 HP too.
Power Steering box: Leaky, I didn't mod that one, it seems to have modded itself.
Factory A/C with a nifty turnbuckle type tensioner made from a couple of spherical rod end bearings and some stainless steel tubing.  12 very well spent dollars to make that part, plan to do the same for the alternator too eventually.  If you have access to a welder make yourself one they're friggin magical. I hate the cheap-assed factory style tension bolts, they're a broken piece of AC compressor casting just waiting to happen.
I run isobutane based stuff as a refrigerant instead of R134a.  Yeah it's flamable, so's the gas in my fuel tank.  Doesn't worry me if it leaks in a soft top tracker anyway.  The stuff works better than R12 (colder by a good 5 degrees or so at the vent which is a good thing here in Phoenix).  It's good stuff, look for EnviroCool on the web if you need to redo your refrigerant.
Duct taped intake tube from the airbox to the crossover tube to the TBI.  Mine tore and I had the duct tape,  ugly but it does the job at least.  Eventually will be replacing it with silicone hose and a piece of metal tubing or something like that.
Need to get a K&N panel filter one of these days too.
That's it under the hood.
Got the 3" calmini body lift and subsequently no back bumper and just the core of the front one.  Doesn't look too bad but I'll eventually put real bumpers on it again.
Running 31x10.50 Dunlop Mud Rovers on 15x7 Black steel rims.
Inside I have a Pioneer Premier CD player and 2 pairs of MB Quart 6 1/2" Separates.  Yeah I know it's probably dumb running em in a soft top but it's not like a window's tough to break if they really wanted in anyway, it just seems less secure.  I got em on ebay pretty cheep from some overstock/liquidation place for like 120 per set instead of the 450 a set they would have been new retail.  If I ever get an amp besides the so-so one built into the deck they'll actually be loud enough to sound good over the road noise with a soft top.  They're just barely adequate as it is.  Probably could put a sub in there too but since they've got a flat frequency response down to 40 Hz they're actually not too bad by themselves and the 2 door tracker doesn't leave much room for a sub box anyway.  Also doesn't attract as much attention as having a sub box could.
That'd be it.
* The original engine has a big hole in the block courtesy of a thrown #1 piston rod.  I've still got it in the garage for the occasional parts cannibalization and to pull the mangled con-rod out of one of these days to put on display.  Every now and then I still find a chunk of the original block somewhere in a corner under the hood.  Really wasn't a bad deal though for me, this is why I got the tracker for free in the first place. It used to be my wife's uncle's when the Rod went and he didn't want to pay 5 grand for someone to replace his engine. He was just going to sell it for scrap or give it away to charity so I talked him into giving it to me instead.   I got a used engine to rebuild for 400 bucks and maybe put another 5 or 600 into it between parts and machining.
I also Cleaned the inside of the block casting up a bit and rounded sharp corners to get rid of potential stress raising points.  Necessary for a pretty mild 1.6? I doubt it. but the smoothed inside surface of the block looks nice.  Not that I hope to have to look at it again anytime soon.
Lastly, if you're going to do the port matching and cleanup yourself without air tools and some good abrasive rolls like the ones in the do it yourself head porting kit,  do yourself a favor and either wait till you get the right tools for it or just pay someone like Asian auto parts of AZ to do it since they flow bench it anyway.  Lets put it in the nicest of terms.  The Dremel just isn't the right tool for the job here. It's like trying to put in underground pipe using a spoon instead of a backhoe.  Yeah you could probably do it but it takes forever and really sucks.  If you're just going to clean up the less than stellar castings and get rid of the casting flash, then a dremel's good enough to handle it.
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: everyones mods
« Reply #37 on: December 29, 2003, 10:34:24 AM »
32 SWAMPERS ARE NOW ON...LOOKING PRETTY GOOD I'LL HAVE TO GET A PIC. AND POST......
GRVIT
Re: everyones mods
« Reply #38 on: January 19, 2004, 08:38:41 AM »
My truck's   Specifications :
Suzuki Vitara  SWB JLX ,1.6L,16v,2001
Suspension
- Calmini 3" super articulation suspension lift
Body lift
- Calmini  3"
Wheels - Tyres
-Yokohama Geolandar M/T 30X9,5X15
Engine
- 1600cc ,16v
- K&N Filtercharger
- Calmini Exhaust Combo
Transmission
- Calmini 5,83:1 Rings & Pinions
- Calmini Anvil front axle
- Steel third member (carrier) from 2.5L,V6 GV
-Centerforce Dual Friction Clutch
-Warn premium "fused" hubs
-Detroit EZ Locker -rear axle
Other Mods
-Calmini Skid Plates (all of them)
-Calmini steering stabiliser
-Calmini idler arm braces
-Safari Snorkel
2004 Mods
- ARB Air Locker front axle or a LockRight maybe
- Winch bumber and winch
- Calmini rockcrawler kit 4,24:1
- 15x7" rims and 31X10,5X15  tyres
Offline zookiemike
  • 474
  • $,reppin Michigan,$
Re: everyones mods
« Reply #39 on: January 19, 2004, 10:22:55 AM »
94 geo tracker/convo/5speed/8valve
old man emu kitt
pro comp prerun light bar
flow master 2in exhaust
hella500's
mickey thomson baja mtx's 225/75/15
blaupunkt casablanca.cd51/kicker 12/and i need a amp
Hopfully a header at the end of the month ;D.
Offline zutefisk
  • 124
  • yumpin yiminy yee viss
Re: everyones mods
« Reply #40 on: January 19, 2004, 11:49:17 AM »
87 Samurai with original Soft Top
-Spring Over on SKY HD spring pads
-Breeze Cross Over Steering
-Sidekick Power Steering
-Hybid Rear Axle
-4.63's
-Locked Front and Rear
-Rear Disks
-Spidertrax driveline ebrake
-High Tec 31x10.5 OTR Mud
89 Sidekick 98k Commuter with leaky Hardtop
-no mods,
-Plans
--fix the leaks,
--find the short in the dashboard lights,
--figure out the unstable idle.
87 Samurai
  • 2274
Re: everyones mods
« Reply #41 on: January 20, 2004, 01:44:49 PM »
old man emu kitt
hella500's
  WHAT DO YOU THINK OF THE OLD MAN EMU  KIT  ???
Offline rabidray
  • 46
  • hey what you want!!!!!!!!!!! !!!!
Re: everyones mods
« Reply #42 on: January 20, 2004, 02:51:06 PM »
ok i have
1987 sammy
webber carb
1.6 8v motor
grs I t-case
hybred rear axel
5.125 gears
arb air lockers front and rear
spoa
drop pitman arm
bds shocks
uniroyal 33x12.50x15 lorado mt,s{5 of em}
warn m-8000 winch
home biult winch mount
the stuff i need to get is
a roll cage
ott kicker t-case
hy steer setup
rear disc breaks
i know im forgetting a lot of stuff but this is just general run of the mill stuff...........................
88 sammy with a few mods
Offline sarmeier
  • 43
Re: everyones mods
« Reply #43 on: January 21, 2004, 12:24:29 AM »
2002 Chev Tracker:
Current mods
2" RRO OME suspension lift
15X7" wagon spoke wheels with 2" backspacing
235X15 Hercules Terra Trak tires
K&N air filter
ARB air compressor
CB
2 meter HAM radio
Upcoming mods
ARB rear locker (ordered)
RRO 2" body lift
30" BFG ATs
Lower transfercase crawler gears
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: everyones mods
« Reply #44 on: January 21, 2004, 07:19:06 AM »
1994 geo tracker
2" homemade lift
calmini header
2"exhaust no cat flowmaster
cobra handset c/b
homemade front bumper/tow bar
drilled lower part of air box
free tires 215/75r15
soon to come,
3" calmini lift
limmited slip dif rear
locker ft
sliders
30x10.5r15 swampers
10x8"rock crawlers rims
belly pan
homemade rear bumper
new radio w/ new speakers
rock crawler t case
roof rack
