honda tracker swap?
  • 16 Replies
  • 6377 Views
Offline zookiemike
  • 474
  • $,reppin Michigan,$
honda tracker swap?
« on: January 16, 2004, 05:11:29 PM »
Hey you think a honda drive train like engine&trany would fit. My thought was to take it spin it cram the back of the trany in the tunnle mount it take the cv's make adbters rig it and drive it. Center diff. think about the posibillitys :o.
Offline Tracker_Gt
  • 33
  • WOB WOB
Re: honda tracker swap?
« Reply #1 on: January 16, 2004, 06:25:40 PM »
if you did that you have to drive a honda and i think that having less power is better than driving a honda unlesss you like stickers and yellow hats
1990 Tracker, 4x4, 5 speed, 1.6, 4 door springs custom exhaust, custom paint, 31/10.5/15  - (sold)
1992 sidekick, 4x4, 5speed, 16valve, 4door, 3" home made body lift, 235/85/16's, (lots of cutting)
Offline Z3bra
  • 273
« Reply #2 on: January 16, 2004, 11:52:51 PM »
The parts availability might be nice, but Honda con-rods are crap for starters.  Plus your Zuk would have that "violated" sort of feeling as if it's heart had been transplanted with that of an evil vehicle.
Also keep in mind Honda engines spin backwards from everyone else which is why most FWD cars have the Tranny on the driver's side and it's on the passenger side in Hondas.
It might be possible but it's probably way more work than it would be worth to adapt a FWD engine/tranny package than something that's at least got a RWD tranny available for it even if the engine is used for FWD and RWD platforms.
Offline Tracker_Gt
  • 33
  • WOB WOB
« Reply #3 on: January 17, 2004, 11:40:12 PM »
if you wanna go with an import engine go wit a toyota 4AG they have about the same potential and there not made by honda which is way more important
personally i wanna see a turbo dodge do into a tracker if i knew where to get a bell housing done id do it myself (2.2 turbo II is my favorite 4 cylinder ever built)
Offline bandit86
  • 1641
  • elv8rguy
« Reply #4 on: January 18, 2004, 06:46:37 AM »
I love the 2.2 chryslers.  last for ever and then some
Offline 1bigtracker
  • 3409
« Reply #5 on: January 18, 2004, 07:21:34 AM »
2.2 turbo probe.  love the power, hate the problems
Offline Jake_Palmberg
  • 43
« Reply #6 on: January 18, 2004, 10:21:56 AM »
trackerGT said:personally i wanna see a turbo dodge do into a tracker if i knew where to get a bell housing done id do it myself (2.2 turbo II is my favorite 4 cylinder ever built)
Just use half the chrysler bell housing and marry it to half your tracker bell housing..... cheap, fast, and easy!!!
Jake Palmberg
44'' boggers were made for samurais!
Jeeps are like tampons,,,every pussy's got one
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #7 on: January 18, 2004, 10:32:22 AM »
Keep in mind that a fwd trans is open diff. So if the front tires come off the ground you just lost your go power. Another thing, each gear in the trans would be a gear reduction. For a rock crawler it might not be so bad but pretty low for anything else. Especially reverse. On top of that... Quite a project.
Mike
Offline 1bigtracker
  • 3409
« Reply #8 on: January 18, 2004, 11:16:29 AM »
they make spools for those honda engines
« Reply #9 on: January 18, 2004, 12:09:01 PM »
Ya well my friend with a Honda CRV, wishes he
bought an XL7 or GV, he put a header on it and
has whopper 215 tires, he says it can't get out
of it's own way, so I'd think twice about a honda
engine swap, Honda  :P
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #10 on: January 18, 2004, 01:27:35 PM »
No offense intended but I'd use my Tracker for a doghouse before I'd put a Honda Engine in it.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #11 on: January 18, 2004, 01:34:10 PM »
pretty soon those v6 suzukis are gonna come down in price.  even without all the electronics, that megasquirt should run it sufficiently
Offline Samurai_Hamster
  • 28
    • Samurai Hamster
« Reply #12 on: January 19, 2004, 01:09:13 PM »
Its against the god of hamamatsu law to put any "honda" engine in a zuke.
If you do that, godzilla will rise from the depths of the sea of Japan, swim over here, and stomp your house to pieces.
Don;t do it.  I know the zuke warrior gods quite well. They would not look kindly on such an act.
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #13 on: January 19, 2004, 01:12:59 PM »
;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
LMAO
Mike
Offline zookiemike
  • 474
« Reply #14 on: January 19, 2004, 01:35:37 PM »
I know Iknow honda evil toyota 4age ok motor but my mr2 was about as kwik as my tracker. Ill build my 1.6/8valve befor any thing drastic :o I just thought the center diff would give a subaru afect. HOT DAM A RALLY TRACKER ;D
