FRONT LOCKING HUB. HOW DO THAY WORK
  • 2339 Views
Offline mr.vacuum
  • 31
  • I just got a 90 sidekick. getting back in to 4x4
    • http://www.camotruck.net/phpBB2/gallery2.php?g2_itemId=463
« on: January 17, 2004, 06:45:07 AM »
HI I JUST GOT A 90 SIDEKICK.. I SWITCH THE HUB'S TO FREE.  AND POP THE CLUCH AND THE FRONT WHEELS SPIN.. IS THIS THE WAY THAY WORK...THANKS ..LES
Re: FRONT LOCKING HUB. HOW DO THAY WORK
« Reply #1 on: January 17, 2004, 06:48:29 AM »
only if they are broken and or stuck! try backing up first after you unlock them 8)
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #2 on: January 17, 2004, 06:50:10 AM »
YEA WHAT HE SAID  ;D
Offline mr.vacuum
  • 31
« Reply #3 on: January 17, 2004, 06:52:59 AM »
thay will not free up. is it a big deal to fix....thanks les
« Reply #4 on: January 17, 2004, 07:04:48 AM »
no just six bolts and maybe a c clip you might need some snap ring pliers other than that real easy to figure out once you are in there, just one sliding part and a spring, check the bushing(or bearing)to make sure it is tight and no slop in it grease it with some light grease after cleaning it but don't put too much of it on and torque it back down to specification and your done.
