8v to 16 v conversion in kick
  • 16 Replies
  • 4846 Views
Offline Mac
  • 407
  • Toys, Toys, Toys
    • 1985 Suzuki Samurai
« on: January 13, 2004, 03:25:40 PM »
Anyone done this, my thought is the whole engine harness, computer, and maybe the dash and gauge cluster, the 16v has a speed sensor ??? the cost could be less and still more power than an 8v with all the goodies.
Thanks
Mac
P.S. can any one clarify when the 16v's came out I thought it was 92 in the 4dr and 94 in the 2dr's
Re: 8v to 16 v conversion in kick
« Reply #1 on: January 13, 2004, 09:18:53 PM »
I thought about this a while back, and all of the information I received confirmed all of your statements above. I was thinking that someone brought up something about the fuel pump or lines also, but I can  not remember what it was. The definately said that the motor, harness & ecu need to be transplanted, but I think the cluster would be fine :-/
Offline 1bigtracker
  • 3409
« Reply #2 on: January 14, 2004, 02:51:39 AM »
Are you guys aware of the power and RPM of the 16V.  when i saw that it scared me so far away from doing that. now i'm just going to work with what i have and see what i come out with when the dust settles.  lata stu
« Reply #3 on: January 14, 2004, 04:36:14 AM »
Yea, that was the main reason I still have a 8V. I like the lower end power and torque range. I'll end up just re-building it or geting another ;)
Offline Mac
  • 407
  • Toys, Toys, Toys
« Reply #4 on: January 14, 2004, 05:24:06 AM »
Ok how far would you go with the cam, isky torquer or z330, I feel you could get away with z330 with out the other hardware on the 1.6 it would never rev like a 1.3 to be a problem with valve float. I ran the Calmini cam in my Sami 1.6 and it helped but it could use a more agressive grind.
Mac
Offline 1bigtracker
  • 3409
« Reply #5 on: January 14, 2004, 07:57:40 AM »
what are you runing for a rig and engine mac?
Offline bandit86
  • 1641
  • elv8rguy
« Reply #6 on: January 14, 2004, 11:10:04 AM »
you're better off welding injector bungs on the intake runner running the four new injectors in parallel off of the old injector wire, using a large throttle plate off a vortec 4.3.   Way less restriction that way.  basically convering to efi setup.
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #7 on: January 14, 2004, 11:46:49 AM »
STU,         1.6 L 4 Cylinder 8 valve with intake
6" Calmini Super articulation combo lift
Auto Transmission
5.13 gears  (open), for now, 12 bolt rear
New 32x9.50 Interco Super Swampers, undecided rims, running BFG 31 x 10.5's on 8" rim
Calmini Steering stabilizer, and front skid plate, not installed yet, power steering , Tilt, cruise, Power windows, Power Locks, Power mirrors, hardtop and soft top
Offline Kreg
  • 795
    • Island 4x4
« Reply #8 on: January 14, 2004, 12:29:26 PM »
Mac has 32 swampers on his rig now.
He sold those BFG's to me.  ;D
(my kick)
« Last Edit: January 14, 2004, 12:30:29 PM by Kreg »
Offline Speedracer7c
  • 2210
« Reply #9 on: January 14, 2004, 01:58:13 PM »
Hows it go with the auto?
Offline Mac
  • 407
  • Toys, Toys, Toys
« Reply #10 on: January 14, 2004, 04:57:25 PM »
It runs great because of the factory 4.62 with the auto the 5.13 out of the manual make for a cheap gearing upgrade from the wreckers. It is my first auto truck and I am loving it, on the hills it kick but over the standard, going down I do miss letting 1st gear carry me down, the auto does not engine brake as well.
Mac
Offline Mac
  • 407
  • Toys, Toys, Toys
« Reply #11 on: January 14, 2004, 05:00:28 PM »
Hey one big click on my web page icon, and you can see the rig.
Mac
« Reply #12 on: January 15, 2004, 04:11:08 PM »
Thats one sweet sammy.
Offline Tracker_Gt
  • 33
  • WOB WOB
« Reply #13 on: January 15, 2004, 06:30:42 PM »
now this 16 valve head every one is talking about is it the twin cam GTI head from a suzi swift cause i hear there easy to swap in all you need is a timing belt from a honda (well asides from the wiring harness which is the scarry part in my books)
1990 Tracker, 4x4, 5 speed, 1.6, 4 door springs custom exhaust, custom paint, 31/10.5/15  - (sold)
1992 sidekick, 4x4, 5speed, 16valve, 4door, 3" home made body lift, 235/85/16's, (lots of cutting)
« Reply #14 on: January 16, 2004, 03:53:24 AM »
No the 1.3 16V twin cam head is not the same,
the Kick 16V head is a single cam, and you can
use the stock belts for the 1.6 16V kick, the block
is the same 16A if I remember right, so the 16V
head is a bolt on option for you.
