Calmini Rose joint spec
  • 17 Replies
  • 4960 Views
Offline mbmarkyb
  • 461
    • UK Vitara
« on: March 31, 2005, 04:03:52 AM »
Hello ,   Does anyone know what thread and size the rose joint is on the calmini 3 inch lift  Rear A arm for the middle axle mount.   I have a feeling mine is on the way out.
I here its not covered under warranty so I thought I would source locally.
Help would be great cheers ....
Markyb (UK)
UK Vitara JLX SE
Re: Calmini Rose joint spec
« Reply #1 on: March 31, 2005, 06:25:55 AM »
I will check mine tomorrow if you haven't had an answer by then, might have to check with Zeus if its an imperial thread. Rallye Design may have some and they do the boots for them too  ;D. Its a bit dumb having an exposed joint on an offroader.
« Last Edit: March 31, 2005, 06:27:00 AM by Rhinoman »
Offline robert_h
  • 30
  • 1.6 liters of fire-breathing power
« Reply #2 on: March 31, 2005, 02:45:37 PM »
Hi,
You're talking about this part, right ? :
According to my trusty calipers, the thread is 3/4" diameter, with 16 threads/inch.
(My new Calmini lift showed up today  ;)    )
  - Robert
« Reply #3 on: March 31, 2005, 05:40:11 PM »
For about $50-70 that open one
can be replaced with a nylon filled
unit that is made of Stainless or forged
aluminum, stronger, and keeps the dirt out
Offline ningram1
  • 84
  • 92 Tintop Vitara
« Reply #4 on: March 31, 2005, 06:42:37 PM »
D'oh! Just ordered a replacement from calmini for mine...
where can you get the uprated ones, Wild?
Cheers
Nick
Chaos, Panic, Disorder. My work here is done.
« Reply #5 on: April 01, 2005, 01:04:47 PM »
An offroad store here in California
called Kar-Tech I think, I got some
parts there for my new 6" lift front
suspension.
They are in Riverside Ca.
post the hole size and the thread
size, right or left thread and pitch,
I'll see what they cost. Smaller ones
I bought were $40 ea 5/8" thread
and 1/2' hole size if I remember right
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #6 on: April 03, 2005, 08:18:13 PM »
Thanks for all the info we can start to order
Markyb (UK)
UK Vitara JLX SE
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #7 on: April 04, 2005, 02:04:56 AM »
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline ningram1
  • 84
  • 92 Tintop Vitara
« Reply #8 on: April 15, 2005, 06:51:43 PM »
Well 2 and a bit weeks later and still no part ..... >:(
Does anyone know the hole size and the thread
size, right or left thread and pitch details so I can try spidertrax, or perhaps Wild can try Kar Tech?
Thanks
Nick
Offline xamtex
  • 72
« Reply #9 on: April 16, 2005, 01:14:38 AM »
god must love crazy people,he made so many of them!!!
« Reply #10 on: April 16, 2005, 09:26:17 AM »
Thanks
Nick
From the information posted by Robert above and looking here:
http://www.bmh.com.au/norton/imperial_thread_chart.htm
its 3/4 UNF stub. I haven't got my Verniers handy and I can't tell whether its a 7/16" bore or 1/2". It is a R/H thread.
« Last Edit: April 16, 2005, 09:49:44 AM by Rhinoman »
Offline ningram1
  • 84
  • 92 Tintop Vitara
« Reply #11 on: April 16, 2005, 07:23:31 PM »
Thanks for everyone's help.
If calmini can't deliver soon, and no one can measure he bore size, I will strip mine off and have a look. I didn't want to be off the road for this, but my truck is almost uncontrollable when you hit ruts in the road.
cheers
Nick
« Reply #12 on: April 17, 2005, 05:52:51 AM »
Well according to my maths 7/16 is 11.1mm and 1/2" is 12.5mm. I've had a look at mine with the Verniers and the bolt looks like an M12 metric bolt but I don't have my thread gauge to hand.  So it could be a 1/2" bore but if the clearance on a 7/16" hole is more than 0.9mm then it could be one of those too  ???
Offline Agent Orange
  • 711
    • Trying to learn
« Reply #13 on: April 23, 2005, 01:03:26 PM »
has anyone figured out the size of this part yet ?
i just found out that mine has some play in it, and that's were my squeeking was coming from.
Offline 90Stomper
  • 427
« Reply #14 on: April 23, 2005, 01:54:51 PM »
dito :P
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
