antifreeze engine block plug
  • 1966 Views
Offline douglas
  • 17
  • I'll keep digging, till I feel something.
« on: January 14, 2004, 07:57:17 AM »
I looked in the full service manual and the haynes, but there was no mention of an engine block plug for antifreeze.  I am going to flush mine out (hose, adapter in line, and bucket) and was wondering if there is one like on other vehicles.
Thanks ???
Drunk on ego.   Surely thought I could make it right if I hit you one more time.  To help you face the nightmare of your life.
Offline Z3bra
  • 273
Re: antifreeze engine block plug
« Reply #1 on: January 14, 2004, 08:09:59 AM »
Other than the actual freeze plugs there isn't one that I've ever seen, just the drain cock on the radiator.  If you're doing a full flush you could just flush it till you see clear water then start it briefly to let the pump circulate it a little bit then flush again till it's clear.
Offline douglas
  • 17
« Reply #2 on: January 14, 2004, 12:50:12 PM »
Good deal.  Thanks.  Someone else chime in if they know that there is one.  I've looked all over.
Offline ntjoe
  • 50
« Reply #3 on: January 15, 2004, 04:06:19 AM »
I've always just used those Prestone Flush Kits that tap into the heater hose.  On another car I had that was just fulled with crap, I ended up taking the radiator to a shop and having it cleaned, and I put a water hose in the top radiator hose w/o the thermostat in it and turned it on.  I ran it until the water coming out of the bottom hose was clear.  Worked good for me.  You also have to unhook both heater hoses and run water thru one for the same effect in the heater core.
Good luck!
1996 Geo Tracker 4WD
1989 Maxima SE 5 Speed
