severe hesitation
severe hesitation
douglas
17
I'll keep digging, till I feel something.
severe hesitation
January 09, 2004, 01:32:46 AM »
Anyone have a severe hesitation on their sammi?  Mine started about 2 months ago.  It always happens when I stop and then accelerate (stop sign or light).  I suspect the accelerator pump on my weber 32/36.  Seems that air is getting in that circuit, which causes a lapse in squirt when accelerating (I have cleaned that circuit and all the jets thoroughly).  I am soon to check the timing too.  I have a 1.3 engine with a weber.  There are new plugs, wires, cap and rotor.  No other engine mods.  Thanks.
Last Edit: January 09, 2004, 01:33:48 AM by douglas
Drunk on ego. Surely thought I could make it right if I hit you one more time. To help you face the nightmare of your life.
wildgoody
8134
67
Re: severe hesitation
January 09, 2004, 02:38:01 AM »
Sounds like a leaking accelerator pump diaphram,
gets some air in there and spits before it squirts.
Good Luck with it
brace
264
I built it; I break it; I fix it.
January 09, 2004, 03:23:24 AM »
I have a factory suzuki on my SJ and the guy before made a second accel. pump diaphram made out of a tire inner tube. I rebuilt it with the a kit from Hawk and now I out run larger mopeds.
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
douglas
17
Reply #3 on:
January 09, 2004, 05:48:22 AM »
Would you see gas leaking from it or maybe the whole might be too small? I looked at the diaphragm and decided that it looked good but maybe not. Keep the ideas coming cause I'm all out of brainstorms.
wildgoody
8134
67
Reply #4 on:
January 09, 2004, 04:26:11 PM »
Blockage in the passage that feeds
the Accel pump, or the 1 way valve,
read bearing with a spring, might be
out of place, rusted, stuck, broken...
Dirt blocking the squirter, you do have
a fuel filter on don't you
if not, dirt
could get in there.
bandit86
1641
elv8rguy
Reply #5 on:
January 10, 2004, 01:37:06 AM »
dont forget the vacum lines, if any. I had a hose come off a PVC valve once, man it was wierd. It would idle crappy, nothing but missfires/ hesitation till full throttle.
