Stuck Transfer Case
  • 2257 Views
Offline Bigdaddy183
Stuck Transfer Case
« on: May 24, 2019, 05:39:30 PM »
A newbie here. Hope this is posted to correct area. I have a 92 Sammy that I shifted the transfer case into nutural then can't shift it into 2H. The shifter goes into 4H and 4L but the driveshaft doesn't turn when lever is in 4. The guy who built my motor said it could just use a new shifter sheet. Could that be it? Or could there be something major wrong with the T case? Any information will be great.
Offline fordem
Re: Stuck Transfer Case
« Reply #1 on: May 24, 2019, 06:12:46 PM »
I'd say it's more likely to be a shifter related issue than anything else - so shifter sheet or pivot bolt - how much slop is there in the shift lever movement?
Offline Bigdaddy183
« Reply #2 on: May 24, 2019, 06:30:48 PM »
There is not much play that I can tell. I have a shifter sheet ordered. Do you have any tips in how to get that dang lock cap off to get the T case shift lever out?
Offline fordem
« Reply #3 on: May 25, 2019, 07:52:28 PM »
