Mods for a bone Stock Sami
  • 2870 Views
Offline Sami88
  • 45
« on: January 05, 2004, 08:01:20 AM »
I have an 88 samurai that i got back in October.  I was wondering what yalls suggestions would be for the first mods.  I'm not loaded so $ is and issue.  The trails i've been on so far haven't been to extreme, but i wouldn't mind hittins some harder stuff.
Thanks,
88
Offline 1bigtracker
  • 3409
Re: Mods for a bone Stock Sami
« Reply #1 on: January 05, 2004, 08:15:17 AM »
well a lift is one major thing.  more stuff is bigger better tires and lockers.  the easest way to lift you sammy is a soa or spring over axle.  the biggest thing to offroad is a locker i think.  lata stu
Offline jagular7
  • 1026
  • Jagular7
« Reply #2 on: January 05, 2004, 08:24:19 AM »
Suggestions will vary, but the mods/suggestions will all depend on the overall tire size you want, then size for future wheeling, and the type of terrain. You want to do some harder trails, but what's harder in comparison.
First thing, usually is taller aggressive tires. If you go too big at first, you'll spend lots of money to compensate. Stick with 2-3 sizes larger, and much more aggressive. Stay with stock rims or find used ones cheap.
Sami's have short wheelbase, so anything to make those short leafs work, the better. So you could look at swapping the rear leafs up front, adding Jeep CJ rear springs, both with expandable shackles, longer travel shocks (doesn't have to be Ranchos, etc.), and keep it all spring under (for now).
Keep the stock gears in the diffs (you'll need to compensate for the larger tires in the t-case, diffs will come later when you get to 31's or larger tires). Add TT mini-spool to the rear (only $100!!!), add Lock-Right (or other driveway locker) up front. Change your t-case gears to the 4.16 set and it'll lower the 2wd as well as give you creeper gears in low.  This compensates for the slight tire change now.
Perform maintenance/tune-up on your engine, change timing belt, add header, free flow exhaust up to 2" dia. add flow through muffler.
Perform maintenance to your axle with new seals. Change all fluids and start off fresh with your time and not previous owners who is probably guessing. Then you've pretty much got a great foundation to start off with. Make necessary mods over the coming year based on how/what you did on the trials.
Folddown windshields, full family cage, cutting of the body, removable doors, etc. all add destinction to your Sami.
Best bet overall is to find other local Sami owners who wheel. Where are you located? Izook has a nice location finder of other Zuki owners.
Lenexa, KS
Offline 1bigtracker
  • 3409
« Reply #3 on: January 05, 2004, 08:34:08 AM »
Yes one good mod i forgot is removeable about doors.  and the best part is itd free!  heres how to do ithttp://www.izook.com/tech/samurai/doors/hinge/doorhinges.htm  lata stu
jdraper
« Reply #4 on: January 05, 2004, 09:52:41 AM »
If you had to do only one mod, I would also say a rear locker.  After that, I'd look into a SOA conversion, larger tires and gears.
Take a look at my Sammy.  I have under $3k in it, including the $800 purchase price, a new head, and a new  radiator.
Offline Sami88
  • 45
« Reply #5 on: January 06, 2004, 08:23:17 AM »
Thanks for the ideas.  The doors are already removable, like that when i got it, and its a blast to drive with them off.
I've seen a bit of talk about the K&N filters, headers and 2" exhaust.  Do those really increase your horsepower that much.  I just oredered a K&N filter.  Mine was needing replaced so i thought i would give them a try.
I don't think i need a tremendous amout of lift.  I don't do any rock crawling.  The stuff i usually do is some mild trails and hit mud holes.  I do need some better tires.  Right now i just have the street tires that was on it when i bought it.  They work ok and have done better than i thought they would, but i need some mud slingers.
This is my first 4x4 and i never have really worked on many vehicles so i'm a little ignorant in some areas.  I'll just have to do it and learn along the way.
Thanks again,
88
Offline 6feetofAIR
  • 127
  • i wanna go to hawaii yayyyyyyyyyyyyy yy
« Reply #6 on: January 06, 2004, 05:58:05 PM »
the best mod you could possibly do is the calmini 6 inch lift combo. look it up and see y. ::)
