Putting in new sub frame
  • 2 Replies
  • 2447 Views
Offline Browning
  • 24
  • ZUKIWORLD Online!
« on: August 30, 2020, 08:30:13 AM »
Found mine has a small rust hole, got a mint one from Alter Ego, cleaned it up then got it dipped in rust paint... so question is has anyone replaced one and do you need to do your alignment after, looks straight forward to a degree but is there anything one needs to worry about?
I like tight lines, big racks and sweet lines, I’m just a sofisticated Redneck!
Re: Putting in new sub frame
« Reply #1 on: August 30, 2020, 10:53:59 AM »
What "subframe" are you referring to?  Second gens don't have a sub frame - if you're referring to the front suspension cross member - there was a recall involving that - there was a "bad batch" of those, shipped out with inadequate anti-corrosion protection, which caused them to rust out.  As far as I know, it's a straight forward remove & replace and then alignment.
Offline Browning
  • 24
  • ZUKIWORLD Online!
« Reply #2 on: September 03, 2020, 01:34:29 PM »
Yes the sub frame up front where the wish bones hook up to, I looked up the recall but that ended already  ::) Looks pretty simple so tackling that in the next few weeks once I find some time
