2000 Chevy tracker
  • 2394 Views
Offline Reider
2000 Chevy tracker
« on: November 22, 2020, 10:15:42 PM »
I have a 2000 Chevy tracker with a 4 cylinder, automatic and was wondering if a 2004 Chevy tracker 6 cylinder, automatic will fit and if the wire harness will match as I have the opportunity to get it if worth while, thanks
Offline fordem
Re: 2000 Chevy tracker
« Reply #1 on: November 23, 2020, 02:42:03 AM »
What is it you're asking about - swapping just the transmission - or - the entire powertrain (engine & transmission)?
As far as I know the transmission will interchange, the engines can also be swapped but that's a fairly involved task.
Offline Reider
« Reply #2 on: November 23, 2020, 09:50:46 AM »
I can get both motor and transmission to replace just wanted to know if it will fit in and if the wire harness is the same.
Offline Reider
« Reply #3 on: November 24, 2020, 07:16:34 PM »
Hoping someone can give me some more advice
Offline fordem
« Reply #4 on: November 25, 2020, 02:49:15 AM »
What more advice do you need - as far as I know the transmissions are interchangeable, and whilst the engines can be swapped, it's not going to be a simple swap - you didn't really expect the four & six cylinder engines to use the same wiring, did you?
Swapping the engines will require pretty much everything to be swapped, engine, cooling system, wiring, ecu, intake & exhaust - and if you want to do it properly, the front & rear axles (the gears are different)
Offline Reider
« Reply #5 on: November 25, 2020, 07:50:46 AM »
Thanks
