4fourart lift kit questions
  • 0 Replies
  • 2416 Views
Offline Gmannewt
« on: July 01, 2021, 08:44:29 PM »
I went with the 4xfourart 3” extreme kit and a rocky road 2” body lift. The shop got it on, looks great so far. I was wondering if any of you came had these issues and what you did to solve with your lift kit.
#1 the front suspension is very stiff. the shop has a thought of fabricating a little longer bracket to attach the control arms to, in effect lowering the front of the control arms. If that were the only option, id probably just stay with the stiffer ride.
#2 front wheels not aligned. did a good alignment fix this, or were camber bolts necessary or even useful?
#3, the linkage to the 4 wheel shift lever is attached, but right at the end. Did you lengthen it somehow? The shop is wondering is he can use the same extension as a jeep.
Thanks
