Steering wheel replacement for 95 Sidekick
  • 1 Replies
  • 1731 Views
Offline LarryK
  • 33
  • ZUKIWORLD Online!
« on: November 22, 2022, 05:19:55 AM »
What kind of bolt pattern am I looking at?
Re: Steering wheel replacement for 95 Sidekick
« Reply #1 on: November 22, 2022, 08:04:51 AM »
OEM Suzuki steering wheels, as, I believe are most OEM steering wheels, fit on a tapered splined shaft - at least, that's how they were prior to the advent of airbags, I haven't removed a steering wheel from an airbag equipped Suzuki so I don't know how those are attached to the column.  If your vehicle is not airbag equipped, you should be able to get a hub adapter to fit whatever bolt pattern you need, Suzuki seems to use the same spline across a wide range of vehicles, however, turn signal cancelling arrangements can be different, so there are different hub adapters available in any given bolt pattern.
