oil pan gasket sj410
  • 2 Replies
  • 1483 Views
Offline ontario410
  • 32
  • ZUKIWORLD Online!
« on: March 24, 2023, 02:23:34 AM »
Hi ,
 i have a 83 sj410. i ordered a new oil pan gasket from megazip as the old one is leaking, would anyone have number for the oil filter as the one on the engine does not seem to have one on it? also i only use the vehicle when the weather is above freezing to should i stick with 5w30 or use 10w30 oil?
thanks
Re: oil pan gasket sj410
« Reply #1 on: March 24, 2023, 01:21:30 PM »
16510-83000, essentially the same filter used on the 1.3 Samurai, I like to use the OEM Suzuki filters and I get mine from Low Range Off Road.
Regarding the grade of oil, the image is from the SJ413 manual, but it's essentially the same image in most Suzuki manuals - above freezing either one will work, the 10W30 is good for temperatures down to around -20*C, and the 5W30 can be used in colder temps.
Offline ontario410
  • 32
  • ZUKIWORLD Online!
« Reply #2 on: May 04, 2023, 02:18:09 AM »
 perfect thank you. i ended up going with 10 w 30
