Transfer Case Spline Count
  • 2247 Views
Offline lil_Truck
  • 1148
  • Eric Gardner
« on: December 30, 2003, 02:05:50 PM »
Do anyone know about the spline count on different transfer cases?
I have a 96 Geo with a spline count of 16.  I know the older ones has a 27 spline.
I got into an argument with a guy one day about it.  I finally had to pull out my extra drive shaft and show him.  I left him speechless and it's hard to do that to this guy!!!
I wounder why they went to a lower count when everthing in the drive train got bigger?
« Last Edit: December 30, 2003, 02:06:39 PM by lil_Truck »
32 MTR's Warn 8000i
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: Transfer Case Spline Count
« Reply #1 on: December 30, 2003, 02:39:19 PM »
Theres only those two as far as I know.
Mike
« Reply #2 on: December 30, 2003, 04:05:10 PM »
Both front and rear drive shaft spares I have, have got 26
splines on them, they do however have 2 missing teeth,
(factory) I'm not sure why, but I was messing around one day
and stuck the slip yoke onto the splines of one of my old front
half shafts, perfect fit.
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #3 on: December 31, 2003, 12:02:49 AM »
When you have the same size shafts, a larger count will give you a stronger shaft.  The splines are smaller so that gives the shaft a larger diameter.
Why change it??
32 MTR's Warn 8000i
