Wild Doors
  • 28 Replies
  • 7852 Views
0 Members and 10 Guests are viewing this topic.
Offline zukizzy
  • 123
  • Give it a bump, see what happens!
Wild Doors
« on: December 31, 2004, 03:08:48 PM »
Here are a couple pics of wilds doors. they are far from done but you can get the shape. :o
we had a good wrench sesion and I got a quick school on kicktracks, now I can at least know what some of you are talking about. We'll be doing this again so watch for good things to come. like some new axle mods a couple brace kits and even some more tube work. ;D
Thanks
Wayne
Clearly a road
Re: Wild Doors
« Reply #1 on: December 31, 2004, 04:02:30 PM »
they are looking good.
Offline Speedracer7c
  • 2210
Re: Wild Doors
« Reply #2 on: January 01, 2005, 02:51:48 AM »
Those look badass!
Offline 92Sidekick4x4
  • 1456
Re: Wild Doors
« Reply #3 on: January 01, 2005, 07:40:55 AM »
they look awesome
Offline whitfield
  • 633
  • 4-dr Kick on 34's
Re: Wild Doors
« Reply #4 on: January 01, 2005, 08:39:12 AM »
Slick,   I like it.
Wild Doors, OR Wild's Doors...   ???    I'm confused...
Anyway, Welcome to the dark side of the Family, Where EFI, Powersteering, and 5.13:1's are the norm.
« Last Edit: January 01, 2005, 08:41:17 AM by whitfield »
Offline explosivo
  • 3157
Re: Wild Doors
« Reply #5 on: January 01, 2005, 09:40:36 AM »
Kick tube doors would rock. I was thinking of running doorless on my rig once I get it done... of course if tube doors for the kick were in production... hey, hey, hey ;D ;D
Wait, power steering? Whats that? :P
omghi2.us[/url]
Re: Wild Doors
« Reply #6 on: January 01, 2005, 03:23:39 PM »
"ArmStong" for those luckie few. I guess I should be happy I got luckie and got the 16valve and ps on my first venture into ZUKISM ;D
BUt I think that if you run without doors you should have something to keep your body in incase of the unforeseen.
Offline zukizzy
  • 123
Re: Wild Doors
« Reply #7 on: January 01, 2005, 03:24:57 PM »
Hey guys had a good day after the newyears hangover wore off :P I got Wild's doors about done and have a few pics I need to get uploaded just no time to do it on dial up. you'll have to wait till I get in the offfice monday. you think I should paint the drive one RED?   ;D
We were talking about easy remove doors a while back and while we were at it wild and I came up with a couple easy solutions. I;ll post some pics later but here is the short version. the stock Kicktrack hinge uses a 8mm pin. that is for all intents the same as 5/16" you can get several pins at home depot or your local hardware store that will slide right in. The best would be a cotterless hitch pin. then a cotter hitch pin with a spring clipat least 2". All you do is take your door off remove the circlip and drive out the stock pin then put the new pin in and re bolt your door. It takes 2 people but you can remove the pins without unbolting the door and go doorless. Pics to come ;D
Thanks
Wayne
Clearly a road
Offline zukizzy
  • 123
Re: Wild Doors
« Reply #8 on: January 01, 2005, 03:27:00 PM »
Slick,   I like it.
Hey whit still looking to get into a trackick but I know you got one to spare ;D too bad your so far away till then it sammys for me.
Thanks
Wayne
Clearly a road
  • 1456
Re: Wild Doors
« Reply #9 on: January 01, 2005, 03:33:21 PM »
Thanks
Wayne
cant wait to see them
Re: Wild Doors
« Reply #10 on: January 01, 2005, 03:44:40 PM »
I just noticed, Did you have to take the fenders off to get the hinges off?
Offline explosivo
  • 3157
Re: Wild Doors
« Reply #11 on: January 02, 2005, 04:12:56 AM »
You do have to take the fenders off to get the hinges off the body, at least.
omghi2.us[/url]
Re: Wild Doors
« Reply #12 on: January 02, 2005, 11:48:45 AM »
Hi all  :)  I'm back from Ocotillo Wells, met up with
PPLTRAK and his dad, they were both driving some
nicely modified kicks, Calmini 3" suspension lifts and
swampers for traction, looking good you guys.
Well for the tube doors, we removed the fenders
so we could get in there and get the hinge pins
out and unbolt the doors, but once the initial instal
is made, and the pins are swapped to the easy pull
hitch pins, the door swap will be much easier, and
fender removal would be optional, tho not as easy
as a Sammy with external pins and hinges.
It might still be a 2 man operation to put the
stock doors back on
Wild doors or Wild's doors, both apply  ;)
« Last Edit: January 03, 2005, 09:53:31 AM by wildgoody »
Offline zukizzy
  • 123
Re: Wild Doors
« Reply #13 on: January 03, 2005, 02:00:51 AM »
Yes we did but wild can take off his fenders in about 30 seconds (like velcro pants ???) so it made it easier. you don't have to but it is way easier if you do.
Thanks
Wayne
Clearly a road
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: Wild Doors
« Reply #14 on: January 03, 2005, 03:12:27 AM »
Those doors look sweeeet ;D. Ya Wild for some reason I don't think you would have wanted those doors on this weekend. I,m still trying to get the mud off the kick.
see ya,
  Kevin
PS Zukizzy I heard that your shop is in menife I live off clinton keith if you ever need help in the shop let me know.
