Finally a SAS kit
  • 13 Replies
  • 7046 Views
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Finally a SAS kit
« on: May 03, 2005, 10:06:24 AM »
At least for some of you that is finally  ;):
Quote of http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=43631
We now have available SAS kit for the Vitara it is available in three kits.
All kits are based on using toyota axles.
KIT 1:
Three controll arms.
Third link crossmember
Panhard Rod.
All mounts and hardware.
$1400
KIT 2
Three controll arms
Panhard rod
Springs
Top and bottom spring mounts
$1800
KIT 3
Three controll arms
Pan hard rod
Springs
Brake lines
Shocks
Shock Hoops
Flipped arm
Drag link
Tie rod
$2750.
Okay this is in NZ (I believe) but it IS a SAS kit  ;)
Some welding involved as far as I can see....
« Last Edit: May 03, 2005, 10:07:14 AM by ed-oorklep »
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline antt
  • 49
    • Outerlimits 4x4
Re: Finally a SAS kit
« Reply #1 on: May 03, 2005, 10:16:31 AM »
actually, its from Overkill Engineering which is based in NSW Australia (those prices are aussie dollars)
its a good kit, saw it in action at a  recent  comp and it flexes extremely well and drives nice on the road still apparently.
LWB Vitara
32in Mongrels
2in OME lift
2in Bodylift
Offline ed oorklep
  • 637
    • Suzuki Vitara 4x4
« Reply #2 on: May 03, 2005, 10:24:37 AM »
Yup indeed, thanks for the correction  ;D
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #3 on: May 03, 2005, 07:13:48 PM »
If i ever get bored of my ARB and IFS I know where to go to get my SAS kit
Markyb (UK)
UK Vitara JLX SE
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #4 on: May 03, 2005, 07:27:45 PM »
Mmmm...... holiday and hand luggage springs to mind for you  ;D ;D ;D
Offline sergi
  • 307
« Reply #5 on: May 03, 2005, 09:44:48 PM »
mmmm
Very nice! ;D Now they need to work on one for a GV ::)
Suzuki Grand Vitara 3dr TurboDiesel
Barcelona, Europe
Aquesta és la meva màquina. Creus que em pots seguir?
Offline overkill
  • 14
    • www.overkill4x4.com
« Reply #6 on: May 03, 2005, 11:26:13 PM »
An action shot of the kit.
I will get some more detailed shots for all to see.
www.omghi2.us/april05/TT05_34_063.jpg
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #7 on: May 04, 2005, 06:57:34 PM »
tell you what would be nice ,
would be just a front conversation that would take the kick diff but running coils to match up the 3 inch calmini lift so you just leave your rear axle alone
Markyb (UK)
UK Vitara JLX SE
Offline overkill
  • 14
« Reply #8 on: May 04, 2005, 07:06:48 PM »
This kit can be set up to any height so you would be able to set so you didn't have to touch the rear.
SAM
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #9 on: May 04, 2005, 07:36:30 PM »
I can see what your saying and nice to have a do it yourself and choice of axles
only one issue,
if memory serves me well, Toy R&P ratios come close at 5.79 compared to say 5.83 calmini ,
So the ring gear ratios would cause a slight issue,
Maybe one option is an extended sammy axle running the kick R&Ps but I doubt my front ARB would fit that housing with out some modification.
Given me some ideas .
PS the product looks great and its about time to for the old kick,,,,
I suppose I keep things fairly stock for ease of parts and changing..
Markyb (UK)
UK Vitara JLX SE
« Reply #10 on: May 04, 2005, 11:50:50 PM »
I if memory serves me well, Toy R&P ratios come close at 5.79
Stock maybe but aftermarket R&Ps - well what would you like? theres a huge choice 6.5:1 would cover most Zuk apps I should think (too lazy to do the maths now)
Offline overkill
  • 14
« Reply #11 on: May 05, 2005, 02:19:45 AM »
only one issue,
Hilux have a 5.29 which is close.
Other options are building a hybrid like the Suzanna. But in all honesty you will pick up a pair of yota axles cheaper than building a hybrid of some sort.
SAM
Offline overkill
  • 14
« Reply #12 on: May 10, 2005, 09:20:27 PM »
here are a couple more detail pictures :)
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #13 on: May 11, 2005, 04:14:47 AM »
yota go up to 7.9 something or other , I was referring to if you kepted your Suzuki rear axle and only wanted to change the front. But if you are going to do it then you might as well change both
Markyb (UK)
UK Vitara JLX SE
