If you had the money --- for a lift !!!
  • 2679 Views
Offline Mac0
  • 91
« on: December 07, 2003, 01:49:55 PM »
  Boy -- the more I read the more I get confused .
 If you had the money -- not a bunch but say $400 to $500 -- what lift would you get ??
 I am looking for :
 Use as a every day ride -
 wanting to put 29" to 31" tires under it -
 someday putting the VW diesel motor in it -
 Keep it kind of a "Sleeper" so to speak . I don't want the extream off road look .. -
 Oh -- And hopefully a bolt on ..
 What would be your ideas guy's -- I'm getting lost .
I feel I asked this before -- but there are so many to choose from ???
 Thanks guy's -- Mac0
Offline UberAsuna
  • 239
  • Asuna Sunrunner 92'
    • Cranky's Ghetto My Website
Re: If you had the money --- for a lift !!!
« Reply #1 on: December 07, 2003, 02:48:10 PM »
what kind of ride u got ???
It's A Zuki Thing, Dig It Sucka ;) :D ;D
Offline Mac0
  • 91
« Reply #2 on: December 07, 2003, 03:23:30 PM »
Opps -- 87' Samurai - stock 1.3 motor for now.
Almost got stuck in some mud here yesterday so it is time for some new tires. It only has 235x15 street tires on it now.
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
« Reply #3 on: December 07, 2003, 03:40:41 PM »
I have the BDS lift kit for about 2 years now with no problems and decent ride. It was bolt on with springs, shocks, all new urethane bushings, dropped pitman arm, new u-bolts, and sway bar relocators for $750. The pitman arm and shocks were optional so if you didn't get them it would drop about $225 or so off the price. What I really like is if you break it they'll replace it.  Check them out |removethispart|@  http://www.bds-suspension.com/suspensionsystems_1suzuki.html . If you click on the contact at the bottom they will send prices if I remember correctly.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline Zuki One
  • 441
    • ZUKI - PICS
« Reply #4 on: December 07, 2003, 03:42:19 PM »
SPOA is the cheapest if you peice it yourself=$129.95 sky mfg z-link    $60 spring perches anywhere     offset rims 15x8.5 $136.99-4wheel parts lynwood,wash(if you want a tire wider then a 9.50)  ==$326.94 ($200 with out rims)before tires you really can't get cheaper then that unless you have tires&rims allready and there is only a small amount of welding required for the amount of lift received forso few pennys in my mind this is the cheapest and most affective lift for your buck ;D
« Last Edit: December 07, 2003, 03:45:30 PM by Bug_D »
"Sooo What shop built your rig?"hahahahhahahah    www.cardomain.com/memberpage/607888/1
« Reply #5 on: December 07, 2003, 04:11:46 PM »
[url]http://www.puresuzuki.com/shackle_reverse.htm/[url] thats the cheapest most bang for the buck. sky has some bolt on perches and then you will spend alot on other little stuff!
« Last Edit: December 07, 2003, 04:12:44 PM by mrfuelish »
