2wd transmission ????
  • 3017 Views
« on: December 02, 2003, 04:02:56 AM »
I have a 97 2wd tracker and wanted to put it's transmission in my 98 X-90. I think I saw a picture that showed a mimic transfer case on a 2wd transmission :-/ Are they set up like that ???  Will I be able to use the 2wd transmission on my 4wd?? Any thing crazy involved (like switching out out-put shafts?) ??? :-/
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: 2wd transmission ????
« Reply #1 on: December 02, 2003, 09:02:12 AM »
The output shaft is about 2 inches longer on the 2wd. otherwise it looks like it would fit. I thought about cutting 2 inches off and see if the splines went deep enoughh to mesh. BTW some of the newer 2wd transmittions have a weird coarse spline.
Mike
« Last Edit: December 02, 2003, 09:03:18 AM by Mikerpm4x4 »
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
« Reply #2 on: December 02, 2003, 09:08:55 AM »
Put the tranny of your sidekick in the x-90 and put the 2wd tranny in your sidekick with an sammy t-case mated to it.
And by the way fill it with the 8:1 SUPERCrawler gears from Rocky Road Outfitters.
hehehe!
With 5.83:1 r&p your will be the lowest sidekick/tracker on earth! ;D
Fredo
« Last Edit: December 02, 2003, 09:10:06 AM by Fredo »
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
« Reply #3 on: December 02, 2003, 09:41:54 PM »
Fredo,
I'm having enough trouble snapping axles with a 4:1 ;) If I went 8:1 I would have to run in 5th gear al the time  ::) Hey, I could do the 8:1 and 39's on the Kick. Now I just have to figure out how to get 10" more lift :o
Mike,
Thanks, that's not what I wanted to hear  :'( but it saved me alot of time 8) I guess it's time to go looking for one in the local junk yard.
Is there any difference in the 4x4 trans over the years ??? Or will any 89-98 work?
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #4 on: December 02, 2003, 10:25:22 PM »
The 4x4 trans are all the same.
Mike
« Reply #5 on: December 02, 2003, 11:09:26 PM »
You got one ???
Offline Fredo
  • 416
« Reply #6 on: December 03, 2003, 02:30:11 AM »
hummmmm enough gears for turn 39" like a set of 205 hehe! ;D
Fredo
