Eye of round
  • 21 Replies
  • 5042 Views
Offline Samurai_Hamster
  • 28
    • Samurai Hamster
Eye of round
« on: November 08, 2003, 12:38:24 AM »
Just got back from the tire place today.  Come to find out the rims I got are not totally true.  The balance machine has a dial indicator on there and I got to watch the whole process.  Lots more advanced adaptors than when I balanced tires as a petroleum transfer engineer.
Anyway, instead of the cone mount, this place had an adaptor that allowed the wheel to be mounted  on five studs and torqued down.  I saw the runout; three rims were a tad out of runout, the fourth was worse.  The guy did a credible job but did tell me he's seen lots of rims over the last few years, particularly Toyota & Chrysler where the lug holes and/or the center hole is not cast properly.  This means the rim will never be in dynamic balance.  He got me pretty close and the ride is much improved although there is still some vibration at 45 or so.
No charge and they were fast and truthful.  By allowing me to see what was going on , I felt more comfortable that I was not getting a line of bull.
Crabzuki
Re: Eye of round
« Reply #1 on: November 08, 2003, 09:33:48 AM »
Sound like it's time to go custom to me if you can afford it.  :-/
jdraper
Re: Eye of round
« Reply #2 on: November 08, 2003, 10:19:00 AM »
I've got a set of rims that run true if you're interested  ;D
  • 28
    • Samurai Hamster
Re: Eye of round
« Reply #3 on: November 08, 2003, 10:53:37 AM »
Ohhhhhhhh guys, you're killing me!  I am short of funds, holidays, the new tires.............................. :-[
Offline Somer
  • 143
  • Hey, is it suppose to do that!!
    • D2
Re: Eye of round
« Reply #4 on: November 08, 2003, 04:06:51 PM »
I bought a set of rims from Summit Racing and they have the same exact problem.  Mine are so bad that people stop me to tell me that my tire looks like its gonna fall off.  I'm thinking of just going back to my stock rims and 1"spacers.  What a waste of $400 dollars...Summit wouldn't listen to my complaint because I already mounted the tires.  :'(
Re: Eye of round
« Reply #5 on: November 09, 2003, 02:55:54 AM »
LOL my problem is the bent axle flange,
the rim never bent, it was the axle LOL
go figure, I mean it was only a 80 pound
rock I tore up out of the riverbed when I
was doing that donut  :P
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: Eye of round
« Reply #6 on: November 09, 2003, 08:37:06 AM »
 WELL HOW ELSE WOULD YOU KNOW IF THE WHEELS WERE MESSED UP :-/ ...IF YOU DIDN'T USE THEM......SOUNDS LIKE SUMMITT NEEDS A LITTLE BETTER CUSTOMER RELATIONS :o...CAUSE ITS STORIES YOU HERE LIKE THIS THAT MAY MAKE YOU CHOOSE A COMPETITIVE VENDOR ::)...WHEN 2 SEEM TO BE EQUALLY A GOOD DEAL ...IT THEN GOES TO WHAT YOU'VE HEARD OF VENDORS IN QUESTION.........SOUNDS LIKE POOR SERVICE SUMMIT  :'(
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: Eye of round
« Reply #7 on: November 09, 2003, 10:47:46 AM »
Hamster, did it shake before the coopers were put on? If not then they are full of it. Also, The adapter they are useing to balance by the lug nut holes are famous for being crap. I dont belive that BS.  Ive never seen an aluminum zuki wheel spin anything other than perfect.
Mike
  • 28
    • Samurai Hamster
Re: Eye of round
« Reply #8 on: November 09, 2003, 10:58:10 AM »
For MIke Hagen:
No, did not shake
Also these tires are on steel, not aluminum rims.
Third, these tires are mounted on 4 rims I got from a guy in State College who took them off his 2000 Vitara and put on aftermarket alloy wheels.
Sooooooooooo.............the saga continues......... :-/
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
Re: Eye of round
« Reply #9 on: November 09, 2003, 11:14:58 AM »
By design, no steel wheel is perfectly round. I still think its BS. Have a different tire put on. Id bet anything its the tires.
Mike
  • 28
    • Samurai Hamster
Re: Eye of round
« Reply #10 on: November 09, 2003, 11:21:13 AM »
ya think?
I did see the wheel on the machine and there is out of round to the rim......just a tad, you have to watch closely to actually see it.
Hmmmmmmmm...............can you come out here and take a spin in mine for kicks?  ha ha ha.......bring your buggy and we'll go off road!  ;D
jdraper
Re: Eye of round
« Reply #11 on: November 09, 2003, 11:50:26 AM »
I'd bet on the tires too.  My stock Sammy wheels are waaay out of true (not the ones I'm selling), and the truck still drove fine on them when properly balanced.
  • 28
    • Samurai Hamster
Re: Eye of round
« Reply #12 on: November 09, 2003, 11:54:13 AM »
I wonder how I can advance the arguement its the tires?  Maybe I should go back .............with a baseball bat!
Or threaten them to lie down while Mike Hagen jumps over them in his tracker!
Re: Eye of round
« Reply #13 on: November 09, 2003, 09:03:40 PM »
go to another shop and have them mount your spare on that rim, drive around in the rim with spare. If it fixes the problem, return to the Cooper tire shop tell them what you did, that they are full of %$#|removethispart|@ and you want a new &^%$ tire >:(
« Last Edit: November 09, 2003, 09:03:58 PM by Zukipilot »
Offline Somer
  • 143
    • D2
Re: Eye of round
« Reply #14 on: November 09, 2003, 09:35:54 PM »
The steel rims that I have are actually two pieces, one piece is the round metal rim and the other piece is the center section.  I think that the problem is caused because the center section wasn't welded on very straight.   They do wobble a lot, but I have had no vibration problems on the highway.
Thats what I told Summit.. >:(  Who the #$%^ would ever check to see if a wheel was true or not before mounting a tire. ???  Well, they did offer to take a look at them, but only if I could clean them up and make them look brand new.  Also, they said that if they did not find any problems with them they would send them back with the shipping at my cost.  Thats crazy because then the shipping would end up costing more then the rims themselves.
« Last Edit: November 09, 2003, 09:39:08 PM by Gravel »
