kit calmini+ome
  • 2193 Views
Offline chouze
  • 9
kit calmini+ome
« on: November 27, 2003, 04:46:56 AM »
I want know if the kit 2 .5' OME is married with the arms and support of the kit calmini?
Re: kit calmini+ome
« Reply #1 on: November 27, 2003, 05:03:26 AM »
If you are saying to use the OME and a Cal-Mini A-arm set
the though had crossed my mind, problem is the front CVs
can only flex so far, mine are at the limit of down travel,
so I'm working on a new front axle shaft setup.
The 2.5" lift might work OK, I was looking at the 3" Cal   lift.
Re: kit calmini+ome
« Reply #2 on: November 27, 2003, 05:06:00 AM »
chouze, fill in the info in your bio.
Where you from ???
what Zuke you got ???
What is your E-mail ???
post some pics of the zuke ???
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: kit calmini+ome
« Reply #3 on: November 28, 2003, 07:51:36 AM »
YES THIS IS AN IMPORTANT ISSUE THAT I THINK ZIG BROUGHT UP IN A PREVIOUS POST...FILL OUT YOUR BOI'S , NO WERE NOT LOOKING FOR STREET ADDRESSES OR ANYTHING JUST SOME BALL PARK STUFF..IT HELPS TO GET TO KNOW A LITTLE ABOUT THE OTHERS YOUR CHATTING WITH.....& IF YOU DON'T WANT YOUR EMAIL ADD. OUT THERE FOR THE WORLD TO SEE JUST USE THE PRIVATE MESSAGE PART OF THIS SIGHT  ;D...... ::)       MATTY D.  8)
« Last Edit: November 28, 2003, 07:53:14 AM by NY_SIDEKICKER »
