OK - Who was it ---
  • 11 Replies
  • 4053 Views
Offline Mac0
  • 91
OK - Who was it ---
« on: November 19, 2003, 11:57:54 AM »
  The guy who said to clean the carburetor and the other guy who said to use "Seafoam" stuff ??
 Thanks a bunch --- this thing runs great now. Used a can of Carb. cleaner on the outside and where I could see - then put that Seafoam in the tank and down the carb. -- It took about the whole tank of gas to get the full affect but it did the trick. Hell I had to turn down the ideal !!!    Anyway -- thanks    Mac0
Re: OK - Who was it ---
« Reply #1 on: November 19, 2003, 12:56:35 PM »
I was one of them! also if it is a stock samurai you might want to check out the stock down pipe coming out of the exhaust manifold they are a double walled pipe and they collapse to the size of your pinky on the inside, you can tell if it is the stock one by looking at the top part of it  by the collar with the springs, it will neck down in size by it. ltr. Dennis.
Offline Mac0
  • 91
« Reply #2 on: November 19, 2003, 02:21:01 PM »
  I'm looking at the exhaust manifold and there is no "Down Pipe". Could you discribe this more .
« Reply #3 on: November 19, 2003, 02:25:40 PM »
Between the Exhaust Manifold and the Cat, that's the down pipe.
Offline Mac0
  • 91
« Reply #4 on: November 19, 2003, 02:49:37 PM »
  Ohhhh - ok .  I was thinking of something else.  I think that pipe should be fine - it had a new system put on it not to long ago .  Thanks anyway though.
Offline Zuki One
  • 441
    • ZUKI - PICS
« Reply #5 on: November 19, 2003, 04:29:02 PM »
SEA FOAM isnt  it sweet hey by the way Its me your fellow Washintonion you get any snow last night i know i did about 4inches (I WENT AN PLAYED AT LIKE 3AM) so hey you like that stuff?We need to get together an do sum wheelin we have a group a unoffical C.O.R.E. run (about 12 rigs) this sunday at Reiter Pit we are goin up to the Wall! although you wont make it up to the Wall there are hundreds of easy to moderate trails their an iam game to hit all!So let me Know?www.core4x4.com
"Sooo What shop built your rig?"hahahahhahahah    www.cardomain.com/memberpage/607888/1
« Reply #6 on: November 19, 2003, 09:43:05 PM »
What exactly is this "Sea Foam" stuff??? ???
Offline Mac0
  • 91
« Reply #7 on: November 20, 2003, 02:42:20 AM »
  It cleans crud !!!!
 I added it to the gas tank and ran almost the full tank through it. Also opened the aircleaner while it was running - reaved it up a bit and slowly poored some down it. Right at the end I dumped a bunch and choked the engine off. Let it sit for 5 or 10 minutes and started it up. Blue smoke all over . Before I did this it would not ideal worht a darn - now I had to back it down. I also put some in the crank case and will change that today. On the dip stick you sure can tell that it got a lot dirtier -- fast --
Offline Zuki One
  • 441
    • ZUKI - PICS
« Reply #8 on: November 20, 2003, 05:07:38 AM »
SEAFOAM it is a additive a small engine lube that can be purchased at NAPA an other small auto stores it can go in anywhere its good for winterizing for those cold starts! I always dump a quarter of acan in my tank b4 hittin the trail. If i remember correctly it is made in Michigan all i know is ilove the stuff and stand by it.There is a another SEAFOAM product cxalled deep creep it is a carb cleaner and the best pentrating lube ;D
« Reply #9 on: November 20, 2003, 06:30:17 AM »
you have to be care full with it, do not use to much at a time or you will clog your cat. and maybe your muffler. the stuff is good you can use it on your gun's and all kinds of machinery, strong stuff!
Offline Mac0
  • 91
« Reply #10 on: November 20, 2003, 06:45:09 AM »
  What Cat ---  ;) ;) ;)
« Reply #11 on: November 23, 2003, 10:35:44 PM »
Yea the only cat I have would be realy pissed off haveing to clean it out of her fur ;D
