Need some help with rearend problems
  • 22 Replies
  • 6898 Views
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
« on: November 17, 2003, 01:41:32 AM »
I was leaving work yesterday in my 87 samurai. And I start hearing this ticking noise. It sounded like it was coming from the back of the samurai. Within a mile or 2, the noise got really loud and somewhat highpitched. Click! Click! Click! repeatedly over and over again. I noticed it only made the noise when I would give it some throttle. I slowed down to check it out, and the slower I got, the louder the noise got. When I had slowed to about 25-30mph it turned into a vibrating popping noise. POP POP POP! By the time I had slowed down to about 10-15mph everytime it would POP, the whole samurai would jerk really hard. I made a complete stop and climbed under my samurai. Driveshafts are all in place, nothing appears to be broken. I get back in it, stick it in gear and slowly move forward. It went about 4inches then BAM!! It felt like the rear-end was trying to lock up. Every 4-6 inches BAM!! I thought it was going to jerk the dash out. I had a friend come and I told him get in and just ease it forward. He did so, and when it "locked up" the rear end itself just twisted the leaf springs a little and looked like it was trying to roll forward then BAM!! it broke free, made it another few inches and did the same thing... Now my question is, does anybody know exactly whats wrong? And, can it be fixed, or do I have to replace the whole rear end. And, does anyone have the parts to fix it. I have the money... If I have to replace the whole rear-end, im going to go find some toyota axles to put in it.. Any info or help would be greatly appreciated seeing as how i am out of a car at the moment.
                   Thanks so much
                              Brian
jdraper
Re: Need some help with rearend problems
« Reply #1 on: November 17, 2003, 02:05:12 AM »
I'd look at your universal joints first.  Make sure they aren't toast before you dig into the rear. I'd also try disconnecting the driveshaft at the rear and rolling the truck forward by hand to try and isolate the problem.
It's possible you broke the ring or pinion gears, or maybe the spider gears.  Are you locked in the rear??  If so, it could be the locker has a problem.
« Reply #2 on: November 17, 2003, 02:19:13 AM »
Definately determine that it is not the U joints first, but that sounds just like what happned when I broke 2 teeth off of my ring gear in the tracker. Luckily the chunks fell to the bottom and I was able to drive it home without further damage, but I did have to but a ring and pinion.
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
« Reply #3 on: November 17, 2003, 02:29:55 AM »
Im positive its not the U-joints. We checked them all out. Im almost 100% sure the problem lies within the rear-end.. The rear-end is completely stock and original as I know it. How hard is it to change out the ring and pinion gears, and is there a step by step I could read to do so? Ive never opened up a rear-end before. (never had any probs with them until now). Does anyone know about how much a Ring and Pinion gear costs?
Offline okezuki
  • 51
« Reply #4 on: November 17, 2003, 02:46:32 AM »
Pull the third member. Possible broken spiders or even a few backed out ring gear bolts. :(
87,33`s,6-1 t-case,d.c.drive shafts,locked,m/l with cj`s,dt8000`s,& the will to BEAT THE SNOT OUT OF IT!
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
« Reply #5 on: November 17, 2003, 04:48:28 AM »
How much trouble would it be to swap in a 10bolt GM rear end out of a 4WD S10 Blazer? Has anyone ever done that, and would it be worth it? I would think it would be stronger because some of them had a 4.3 V6, but then again, I dunno......
Offline 6feetofAIR
  • 127
  • i wanna go to hawaii yayyyyyyyyyyyyy yy
« Reply #6 on: November 17, 2003, 05:01:31 AM »
i had a similar experiance but without the pop noize, mine was more of a grinding sound, i had a wheel bearing go bad in the rear, by the time i got it home i had wore half of the seized brarings flat! :o
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
« Reply #7 on: November 17, 2003, 06:02:06 AM »
Can you buy ring and pinion sets seperately, or do you have to buy the whole rear-end. I just called a couple junk-yards and they want 350.00 for a factory suzuki samurai rear-end.......   :'(
Offline 1bigtracker
  • 3409
« Reply #8 on: November 17, 2003, 07:39:03 AM »
thats crazy,  if you have the skills and a welder and other parts why not just drop a Tracker rear in it.  the ring and pinion will be diffent.  lata Stu
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
« Reply #9 on: November 17, 2003, 09:06:25 AM »
What are the advantages and disadvantages of the tracker rear end? Are they stronger? I need something thats going to be able to handle around 280lbs of torque.
Offline 1bigtracker
  • 3409
« Reply #10 on: November 17, 2003, 09:12:43 AM »
all around stronger and what chevy are you going to get 280lbs of torque?  lata stu
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
« Reply #11 on: November 17, 2003, 09:16:27 AM »
Im in the process of building another 229 to drop in it.  With what were doing to it, 280lbs is a guestimate. We dont know for sure, it could be less, could be more.....
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #12 on: November 17, 2003, 02:07:03 PM »
A SAMMY ON STEROIDS ...YA GOTTA LOVE IT...WILL BE WAITING FOR SOME PICS.  ;D
« Reply #13 on: November 17, 2003, 05:32:13 PM »
Just replace the 3rd member, here in So. Cal the pick your own
part wrecker only wanted $20 for a rear axle, maybe they mis
understood Axle shaft for whole thing ???
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
« Reply #14 on: November 18, 2003, 12:42:24 AM »
Ya, thats what im going to do. I met up with another guy from here that happen to have one for sale. So, im going to buy it from him and install it.
What are the basics of replacing the 3rd member? Ive never opened up a rear-end before, but I pretty much know how it works... I know once the cover is off, there is a clip on each axle that you have to take out, then you can slide the axles away and the 3rd member is just sitting in place... Am I correct?
Also, what else would anybody reccomend I could do to it to help it last longer? Any tips or tricks? Gear oil suggestions?
