Removing Dash - HELP!!
  • 2958 Views
Offline DanMan2k06
« on: May 07, 2005, 12:54:36 PM »
I am currently in the proccess of re-painting the interior of my 89 sidekick. I've gotten everything done except the main dash panel. I took the steering wheel off to try and remove it easier, but the dash still wont fit over the wiper and blinker controls. Is there any way to remove these controls without taking out a million other bolts or having to reassemble a bunch of intrecate parts? Thanks...
Offline PWSX3
  • If it's a 4-wheel drive it should be off-road
Re: Removing Dash - HELP!!
« Reply #1 on: May 07, 2005, 03:13:52 PM »
I can look at our donor Tracker tomorrow but if it's the same as your Sidekick there is a lot of wiring that will hold the dash from coming off.
1987 stock for now Sami for my 15 year old's first vehicle.
We Wheel with a 1994 Ford Explorer 5" Superlift, 35" tires, locked in the rear, custom tire rack, sliders, misc. stuff.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #2 on: May 08, 2005, 03:24:29 AM »
2 bolts under the dash hold the shaft up. You should be able to remove those and lay the steering shaft down enough...
Offline trackermad
  • 150
« Reply #3 on: May 09, 2005, 08:29:45 AM »
If the 89 is the same as my 94 you just need to remove the plastic cover around the colum if you havnt allready.  Then there are 4 screws near the center that hold the directional assembly in place then just unclip the wiring and slide the hole assembly off.  Also dont forget to pop the dash center plate off (around the radio) and take out the two screws that hold the heater controlls off.  That way you can just leave the controlls behind and not have to disconect the cables.
"First of all: what is work? Work is of two kinds: first, altering the position of matter at or near the earth's surface relatively to other such matter; second, telling other people to do so."  ~Bertrand Russell
Offline SnoFalls
  • 1358
« Reply #4 on: May 09, 2005, 10:14:12 AM »
lotsa work to  ... paint a dash ::)
I (partly) understand ricing some things but ... a tracker :P
Offline Cwkick
  • 888
« Reply #5 on: May 09, 2005, 10:20:37 AM »
He is repainting the interior.  I would guess that means A-piller, targa bar, doors, and such.  Not painting the dash and vents and the like.
Cwkick
Offline Digger
  • 1991
« Reply #6 on: May 10, 2005, 12:55:42 AM »
I thought 89's didn't have much interior cladding at all, mainly just lots of exposed painted metal...
