anyone have a right rear axle with a good bearing
  • 1977 Views
Offline 6feetofAIR
  • 127
  • i wanna go to hawaii yayyyyyyyyyyyyy yy
« on: November 12, 2003, 04:54:37 PM »
for a samurai? my bearing went out on the way to pismo today, i hear its 100 for the bearing plus you have to get it pressed in and out, looking for the cheapest solution to get on the road by saturday night, any help is greatly appreciated, 6feet 8)
Re: anyone have a right rear axle with a good bear
« Reply #1 on: November 12, 2003, 08:31:06 PM »
Call Hawk 1-888-samurai. I would definately reccomend getting new bearings. But I bet you could get an entire axle shaft w/ bearing from Hawk for the $100 your looking at. I dont remember the bearings being near that expensive (maybe installed for 100 ???)
Offline Z3bra
  • 273
« Reply #2 on: November 13, 2003, 01:11:51 AM »
It's a bit late, but I replaced my rears on my Tracker a bit over a year ago and it was nowhere near 100 bucks for a new bearing.  More like 20.  I may be wrong, but I believe the bearing retainer is the same on the track/kick as it is on the sammy.  It's the bearing which is pressed on to the axle and then there's a retaining ring which is pressed on behind that to hold the bearing in place.
The real nusiance of putting a new one on is that you have to grind off the retainer ring with an angle grinder which takes friggin forever. (Took me like 30+ minutes per axle if I recall correctly.)  After that it was a pretty easy fix.  I've also got a friend with a 20 ton press in his garage courtesy of Harbor Freight so that helped too.  Even still you shouldn't be looking at more than 20 bucks to have an auto machine shop press the old one off and the new one on for you if the ring's already gone.  That part of it only took about 10 minutes if that.
Also make sure you replace the axle tube seals when you do this, if the bearing has been worn it means that the seals have probably taken a beating too.  Plus to replace the inner seal you need to pull the bearing anyway.
« Last Edit: November 13, 2003, 01:13:47 AM by Z3bra »
Offline brlj
  • 512
    • Bills 93 Tracker
« Reply #3 on: November 13, 2003, 11:59:28 AM »
Is the bearing and the plate that holds the axle on the housing 1 piece?
Bill
