3 inch Body Lift
3 inch Body Lift
van7559
145
I'll Leave Tracks All Over Your As$
3 inch Body Lift
November 11, 2003, 02:28:28 PM »
i HAve a 95 tracker and just had a three inch body lift put on. Calmini says you can't use your old boots, so what did you guys do?? I can't have a gapping set of holes in my truck
95' Kick with a 3 in. body lift and plenty more to come!
NY_SIDEKICKER
2274
YOU WANNA RACE THE ZUKE !
Re: 3 inch Body Lift
November 11, 2003, 02:30:14 PM »
MY BOTTOM ONE IS ON WITH NO PROBLEMS....... BUT TOP BOOT WAS RAISING HOLY HECK WITH POPPING TRANNY OUT OF GEAR , SO ITS NOT BACK ON YET..BUT WILL PROBABLY BE LOOKING INTO GETTING IT BACK ON SOON.......
http://www.cardomain.com/id/nysidekicker
http://community.webshots.com/user/nysidekicker
Natebert
1098
November 11, 2003, 03:54:15 PM »
We are using BOTH of our old boots on our 3 inch body lift. (we extended both of the shift levers 3 inches too)
But we did have to flip the 4wd shifter boot around to keep it from pulling it out of gear.
~Nate
25
Reply #3 on:
November 11, 2003, 09:06:11 PM »
I also have both boots. I also extedned both shifters, but I bent my console mounting brackets to move the console back about 1/2 inch and it works fine.
1bigtracker
3409
F*** trail rated, try trail tested
Reply #4 on:
November 12, 2003, 12:27:34 PM »
The inside of my tracker is bare bones.(other then the CD player and heater) the floors are coverd in about 3 heavy coats of under body liner and its all muddy and crapy looking so only having the small shift boot fits it great. I had hole in the floor from other stuff untill i went up the riven(A.K.A a hole that on a watery day the water goes over the hood) and the water came though the floors and up to my wast. hello cocking gun. lol lata Stu
 ÂÂÂÂÂÂÂ
tonka-toy
154
tonka
Reply #5 on:
November 13, 2003, 12:53:31 AM »
the base rubber on the 4wd shifter ( the one that looks like someone has cut out a starfish) all i did was to cut this front to back and no more jumping out of 4wd for me
