ALMOST A DISASTER!
  • 2818 Views
Offline okezuki
  • 51
ALMOST A DISASTER!
« on: October 25, 2003, 05:56:19 AM »
Well, I just found that my steering rag joint was riped almost in two! This was a replacement from the "help" section in most auto part stores. Please check yours once in a while, it would be a bitch to lose your steering! I guess I will fire-up the lathe& mill to see if I can make a better product! ;D
87,33`s,6-1 t-case,d.c.drive shafts,locked,m/l with cj`s,dt8000`s,& the will to BEAT THE SNOT OUT OF IT!
Re: ALMOST A DISASTER!
« Reply #1 on: October 25, 2003, 11:34:40 AM »
Go back and get a refund......then stay away
from that Taiwan Crap, especialy where it's
a saftey related item.... geezz you could have
been a sardine...in a tin can :-/
My steering gear is U-Joints on both sides,
look for some used ones from an 89 Kick
from Hawks.. They will hold and they aren't
rubber tire leftovers.
Offline suzsami
  • 41
  • 1987 Samurai
« Reply #2 on: October 29, 2003, 11:34:57 AM »
  I almost had a disaster too , I have a 87 sami , finished the spring over , put in the z bar eliminator , took it out to see what it would do .. got home to clean up my mess swep the carport and guess what I found ? :o
a cotter pin the goes into the steering arm .. talk about glad it didnt come apart . at least yours wouldnt have been your fault ... maybe Im getting to old to remeber everything , well maybe Im just lucky enough to find it before anything happens ..
 But Im glad you figured yours out too ..
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #3 on: October 29, 2003, 01:57:47 PM »
What's a "steering rag joint "?  ???
Offline Mike71
  • 1449
« Reply #4 on: October 29, 2003, 02:58:33 PM »
round of aplause for the man that sweeps up his work area B4 going out to play =)
i think for the rest of my life i will make sure my work area is as  clean as the day it poured lol
o yah wahts a rag joint?
« Reply #5 on: October 30, 2003, 12:13:18 AM »
It's a U-joint made out of what looks like
tire leftovers, or a Semi Truck mud flap.
Rubber bonded together with fibers inside.
