MPG #?
  • 20 Replies
  • 5749 Views
MPG #?
« on: October 20, 2003, 05:11:51 PM »
All this talk about milage but no #.I got a 95" w/32 & 5.83.I get about 160 to a tank w/a 1.5 gals to spare. Roughly 20-21 mpg .Is that about the average?
10 post down.190 to go
« Last Edit: October 20, 2003, 05:14:07 PM by trickker »
Offline tonka-toy
  • 154
  • tonka
    • tonka-toy
Re: MPG #?
« Reply #1 on: October 20, 2003, 07:03:40 PM »
you are gettin more to the gallon than i get from mine
i tank her up and run about 125 miles before needing to fill very very quickly
i reckon about 16-17 mpg
sad but worth it when we kick landrover ass. ;D
« Last Edit: October 20, 2003, 07:03:53 PM by tonka-toy »
Re: MPG #?
« Reply #2 on: October 21, 2003, 12:02:30 AM »
Hey Simon, don't forget they are smaller gallons too :( I get around 25 to a full size imperial gallon.
« Last Edit: October 21, 2003, 12:03:29 AM by Rhinoman »
Offline pesuazo
  • 26
Re: MPG #?
« Reply #3 on: October 21, 2003, 09:20:55 AM »
I drive a lot from Asheville, NC to Clayton, NC. It is about 280 miles. I make it there with 10 gallons driving at 75-80 MPH. That is 28 MPG.
I have a 1994 Tracker 2WD
1994 Geo Tracker 2WD Conv.   145000 Miles
1986 Mercedes Benz 300E        140000 Miles
1998 Mitsubishi Galant               103000 Miles
jdraper
Re: MPG #?
« Reply #4 on: October 21, 2003, 12:05:52 PM »
I'm getting around 20mpg.  I'm running 32's with a 4.16 xfer case re-gear.
Re: MPG #?
« Reply #5 on: October 22, 2003, 04:51:55 AM »
Divide miles by gallons or
Km by L .
160 miles in a 2 door
or 4 door?, 4 door has bigger
tank, I always got 20-22 MPG
89 8V 1.6L 2 door Conv Stock.
now with 31" and stock gears
turbocharged I get 180 miles/tank
about 18 MPG.
You must specify what vehicle you
got, engine type and tire size/gearing
or the numbers don't mean squat.
Offline Mike71
  • 1449
Re: MPG #?
« Reply #6 on: October 22, 2003, 10:22:08 AM »
i have a completely stock 91 2 door tracker i was getting 14-15 mpg untill i changed the spark plugs last week
i havent used a full tank since i changed the plugs but it was full and now its a litle less then half at 130miles  so isnt that 26mpg? or near
Re: MPG #?
« Reply #7 on: October 22, 2003, 10:34:06 AM »
Unless they fit the Tracker with a bigger
tank, you are about 23 or 24 best guess.
run it to the E, fill it up and divide miles
by the gallons you put in, Wala  MPG!!
Re: MPG #?
« Reply #8 on: October 22, 2003, 10:44:54 AM »
I'd figure its a given being mines a 95, its got the 16v and doesn't everybody have a 2dr conv?Just kidd'in, sometimes I would like a 4dr (bout every time I pack up to go wheelin).I'm trying to find a good way to put a x-tra gas can on that CALMINI swing away back bumper.
Re: MPG #?
« Reply #9 on: October 22, 2003, 11:13:04 AM »
4 doors might be nice, but when the going gets
tight, I'm glad I'm 2 feet shorter, the turning
radius is still kind of bad with 33"s on it.
need more room, build a small hauler trailer
for the gear and spares, might even be able
to pull a pop-up camper with an extension on
the front for all your junk to ride in .
:D
Offline Natebert
  • 1098
Re: MPG #?
« Reply #10 on: October 22, 2003, 05:18:56 PM »
We were running;
31 inch tires.  (now 33s)
5.83 gears
1.6L 16v
4 door
K&N air filter
2 inch exhaust (no header)
high-flow catalytic converter
flowmaster muffler
3 inch body lift
3+ inch custom suspension lift
~500lbs extra gear bolted to truck.  (bumper, stereo box, etc)
Roof rack (extra wind resistance)
We are getting about;
~18-20 mpg highway
~16-18 mpg city
I feel that this is about right with all of the modifications.  NONE of which help m.p.g.
Hope this helps.
~Nate
Re: MPG #?
« Reply #11 on: October 22, 2003, 05:41:28 PM »
  I'm running with a K&N and a turbo muf.Any place special for a high fRe: MPG #?
« Last Edit: December 31, 1969, 04:00:00 PM by 10/23/03 at 05:44:54 »
Re: MPG #?
« Reply #12 on: October 23, 2003, 02:07:04 PM »
How did that happen? I meant whats a good High-flow cat for the tracker?Who makes them and whats the going price for one these days? Haven't had to deal with a cat B-4.
Offline Natebert
  • 1098
Re: MPG #?
« Reply #13 on: October 23, 2003, 03:56:05 PM »
Since its illegal to replace a working cat.  I just asked my local muffler shop to inspect my 'severely damaged' stock catalytic converter.  They didn't hesitate to replace it with my supplied DynoMax high flow cat.
*grin*
It was about ~$90 from discount converter dot com
~Nate
Offline Z3bra
  • 273
Re: MPG #?
« Reply #14 on: October 24, 2003, 12:37:53 PM »
And just remember that big rocks are awfully rough on Cats so if you need to make it happen to facilitate a replacement that's always an option.  Heck I bet a big rock on a floor jack in your driveway would do the trick even if you accidentally missed the framerail and jacked the rock into the cat.  But of course that would be illegal so whatever you do, don't do that.  ;D
