4 speed auto conversion
  • 2067 Views
« on: October 10, 2003, 03:31:39 AM »
Has anyone done a 4 speed auto conversion on the '90 3 speed Vitara(Sidekick)?
I'm trying to find if the 4speed has a lock up converter,if the 4 speed is controlled by the ECU, and if the 3 speed's drive shafts will fit with the 4 speed. How about Trans mounts?
Any advice appreciated!
Peter W
Peter W.
'90 Vitara
JLX Soft Top.
S.Aust.
Offline Yankee Tim
  • 431
  • Who says a GV is a grocery getter?
    • Yankee Off-Road
Re: 4 speed auto conversion
« Reply #1 on: October 10, 2003, 04:09:49 AM »
My GV 4sp has a lock up, I believe (and I can hear it when it happens).  It's the same tranny as in the late model Kicks.
I think Blacknight had a link to the wesbite for the tranny with specs.  It's a Aisin/Werner tranny.  Maybe ask him for the link.
The 4sped uses a Kick t-case, so all shafts will work.  Your best best would to swap the entire motor, tranny and harness in.
That help any?
Yankee Tim
« Reply #2 on: October 10, 2003, 10:49:59 AM »
Thanks for the info, Tim.
Ideally, I'd like to swap in the whole package, but the best price I've found so far is $3,300 Aussie dollars! And that's without the loom, but with the computer.
They're asking $1150 for the trans alone.
While I'm on the subject, any idea if the rear driveshaft needs to be shortened? I understand the 4th ratio is a piggybacked Overdrive, so I'm assuming the overall trans length would be a few inches longer.
Thanks again,
Peter W.
Peter W.
'90 Vitara
JLX Soft Top.
S.Aust.
