confused
  • 9 Replies
  • 2485 Views
Offline bus_driver
  • 479
  • the voices tell me different things
confused
« on: May 05, 2005, 04:54:31 PM »
I was playing with the truck and I noticed that I can put the front of my 92 kick about my knee level height and the oppposite back tire is in the wheel well but when I put the back tire the same height the front tires never seem to compress fully.....I have not yet touched the bump stop....is this becuz of the sway bar? also if I take the sway bar off how does it effect the offroad.
my truck is stock
« Last Edit: May 05, 2005, 04:55:56 PM by bus_driver »
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Re: confused
« Reply #1 on: May 05, 2005, 05:46:54 PM »
First off, The stock IFS doesn't really flex that good.
Second. Ya, Take off the sway bar. I did on mine and its not really that noticable on road and off-road it does help alot.
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
Re: confused
« Reply #2 on: May 05, 2005, 11:58:03 PM »
exactly the sway bar will hwlp alot i made some quicj diconects for mine i will try to post some picks.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline CBTracker
  • 140
  • OH, you think I can't make it through?
Re: confused
« Reply #3 on: May 06, 2005, 12:54:47 AM »
Yes, please some pics of your disconnects he he, I'm all up for the pics...  ;D
96 Tracker 2dr on 215s, 2inch suslift soft top, GPS Nav, Light bar.
89 Tracker 2dr hardtop, 235s 1inchsus custom body work, push button starter
Offline bus_driver
  • 479
Re: confused
« Reply #4 on: May 06, 2005, 05:23:55 AM »
yeah I was surprised that i was not on the bump stps yet and I was lifting the rear tire?
if the sway bar does not make that much difference is the quick disconects worth it?
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: confused
« Reply #5 on: May 06, 2005, 05:48:13 AM »
I took the swaybars off of both of my Trackers and I don't miss it at all. For me, disconnects wouldn't be worth it, I would leave them disconnected all the time and wouldn't want to add the weight of a useless swaybar back onto the truck.
When you were lifting a tire, how were you doing it? with a jack under the a-arm or under the tire? The tire would have a lot more leverage on the spring than a jack under the arm, because it's the furthest point from the pivot... Whenever I've jacked up my rig from the a-arm, it behaves differently than when I drive that tire up on a rock or log. The jack raises the frame more than just lifting the tire, which would lift the rear tire more...
Offline bus_driver
  • 479
Re: confused
« Reply #6 on: May 06, 2005, 09:54:04 AM »
I was driving up a wall behind the price chopper while my wife was shopping it has a gradual height change the farther you go along and I was just trying all different things I got to about knee level and then started to look at the suspension and did the comparison at that level
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline madvitara
  • 45
  • Mud i love it
Re: confused
« Reply #7 on: May 06, 2005, 08:05:41 PM »
bin the bar,
i binned my sway bar months ago and you don't miss it at all on the road if your running big tyres. might be different your running a road tyre but y would articulation be a problem then?
Offline SnoFalls
  • 1358
Re: confused
« Reply #8 on: May 07, 2005, 01:52:59 AM »
Another voice about ditching the bar ...
I pulled mine off and couldn't tell any difference on road.
Offline bus_driver
  • 479
Re: confused
« Reply #9 on: May 07, 2005, 09:55:42 AM »
well that convinces me I will ditch the sway bar the next time the truck is in the air
92 2dr soft top
235/75/15
2 inch lift
custom mud
