unmodified idler arms
  • 2991 Views
Offline brlj
  • 512
    • Bills 93 Tracker
« on: September 25, 2003, 11:46:48 AM »
I was just wanting to see how many Tracks/Kicks are running unmodified idler arms here? I will do a write up and submit it to Eric and he will check it out. Im sure some rearranging and changing will need to be done to the article by Eric so hang on guys..   ;)
Later,
Bill
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: unmodified idler arms
« Reply #1 on: September 25, 2003, 12:19:12 PM »
Are you talking about the Idler itself or the bracket?
Ive never bent a bracket. Well at least not since I bought the Idler arm brace from Calmini. They should rename that piece Idler arm BRACKET brace! Cause I bend Idlers all the time. :-[ Actually its pretty common problem once you add a front locker.
Mike
Offline brlj
  • 512
    • Bills 93 Tracker
« Reply #2 on: September 25, 2003, 01:18:06 PM »
Im talking about modifying the bracket where it bolts to the frame and adding the piece of angle at the bottom of the idler which you bolt to the A-arm mount. I saw you have the piece of angle at the bottom, you still bend them? The bracket where it bolts to the frame will break at the lower bolt holes.
One thing too is that brace that Calmini sells doesnt work on a Tracker, it is for Sidekicks only (at least thats what the salesman told me.).
Offline Z3bra
  • 273
« Reply #3 on: September 25, 2003, 02:20:27 PM »
That's pretty odd it wouldn't work on a tracker too.  Seems like it would cost more on a joint developed car to have different mechanicals for the same function. Trim I can understand but given the otherwise identical nature of the kick/track I think the Calmini guy might be wrong on this one.  Then again he might be right, stranger things have happened.
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #4 on: September 25, 2003, 02:41:00 PM »
I DID READ HERE BEFORE THAT THEY ARE FOR KICKS ONLY :( BUT I DO BELEAVE EITHER MIKE OR ZIG MODIFIED IT A LITTLE BIT TO FIT THERE RIG ??? HOW ABOUT IT TRACK GUYS WHATS IT TAKE TO FIT A TRACKER ???
« Last Edit: September 25, 2003, 02:41:23 PM by NY_SIDEKICKER »
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #5 on: September 25, 2003, 11:37:32 PM »
You can make it fit a tracker by adding a little tab to the frame. its certainly easier than building a whole new bracket! There is a close up pic on my home page on the bottom left that says Idler bracket.
Mike
« Reply #6 on: September 26, 2003, 12:08:08 AM »
My arm is unmodified and I haven't had a problem with it in the last 2 years (probably shouldn't have said that). Its not a rock crawler though but its seen a lot of hard use
Offline brlj
  • 512
    • Bills 93 Tracker
« Reply #7 on: September 26, 2003, 12:17:33 AM »
Mike,
Ok , I see now what you did with that bracket. I made my own lower support out of 1/4" angle bolted to the A-Arm mount. I didnt build a whole new bracket , but I welded more steel to the existing assembly. Ill do the write up and let you check it out also to see if it warrants an article. :)
Thanks,
Bill
