Newbie question #2
  • 2481 Views
Offline Mudflinger
  • 22
Newbie question #2
« on: September 23, 2003, 11:49:29 PM »
I've been doing some reading up on general 4x4 stuff & cleared out my local newsagents stock of magazines  :)
I've seen a lot of mentions of the front axle being a weakpoint when going off-road.
I mean, how much damage can a stock 'zuki take?
I know a lot of guys really thrash their trucks, or go rockcrawling etc and I can understand how and why things can get messed up doing that, but when do I need to start worrying?  ???
The impression you get from reading this stuff is that the axle will snap like a toothpick at the first whiff of mud or gravelly bits.  :P
Is it supposed to do that?
jdraper
Re: Newbie question #2
« Reply #1 on: September 23, 2003, 11:59:18 PM »
The Zuk axles will stand up fine for mild to moderate offroading.  Dirt and gravel roads will not be a problem!!!  Usually they start having problems when you put much larger tires on, and then go rock crawling.  They can't handle that kind of torque.
Don't know if you have the aluminum housing or the cast iron housing.  If you have a cast iron housing, it can take quite a bit of abuse.  If it's aluminum, it can't take as much.
« Reply #2 on: September 24, 2003, 12:30:11 AM »
I started having trouble with mine when I went to a 4:1 transfer case reduction and 33's. Before that, I had 29's, stock t-case, and rear locker and never had trouble with the axles.
Offline 1bigtracker
  • 3409
« Reply #3 on: September 24, 2003, 11:16:42 AM »
I have 34in swampers on mine and i have played in the mud three times before a broke the aluminum case.  If you don't know already there is a article about how to put a steel case and sammy locker in in the front.
 Happy wheelin newbie   :P  lata  Stu
« Last Edit: September 24, 2003, 11:17:58 AM by 1bigtracker »
  ÂÂÂÂÂÂÂ
