help front a-arm bolt
  • 2898 Views
Offline track_this
  • 332
« on: September 17, 2003, 11:44:33 AM »
i cant seem to get the front a-arm bolt out so i can install my skid plate/bumper(procomp). i got the nut off of the back side but cant seem to get the friggin bolt out any idea's?
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
Offline Natebert
  • 1098
Re: help front a-arm bolt
« Reply #1 on: September 17, 2003, 12:28:56 PM »
After trying to  turn bolt using a 24 inch breaker bar and twisting rubber bushing in half.  We used a sawzall and sawed off the head, then replaced bolts.  Of course we were replacing the bushings anyway with the Calmini 2 inch lift.  Sorry, but the driver side bolt was impossible to remove on our truck.
maybe try some WD-40 over night.
Good Luck.
Offline track_this
  • 332
« Reply #2 on: September 17, 2003, 06:43:47 PM »
do you mean that both of the bolts would not come out? also i see you installed the bumper, on the top where they say to use the self tapping screws, did those work, because i even drilled a pilot hole and they striped right out. thanks
rear lockright
31" kumho m/t's
Offline Natebert
  • 1098
« Reply #3 on: September 18, 2003, 03:50:42 AM »
We got one side out, undamaged, we let it soak, overnight with liberal amounts of WD-40 applied every few hours.  The otherside was frozen solid in the bushing and we ended up ripping the bushing trying to get it out and had to resort to the saw.
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #4 on: September 18, 2003, 05:06:46 AM »
The self tappers never really worked. We ended up having to put some larger screws on there. However, whenever we gave the skid plate any abuse or took it over washboardy roads the screws would sometimes come out. Since we don't have our front bumper plastic cover attached, we just tack welded the tabs directly to the front bumper metal base. Problem solved for now. We will be getting rid of the bumper soon. We need more approach angle in the front.
Heather
Heather Galvin
Offline brlj
  • 512
    • Bills 93 Tracker
« Reply #5 on: September 21, 2003, 02:28:51 PM »
When I installed my 3" lift I had to cut all but 2 of the a-arm/control arm bolts. No parts store had those sizes with the same shoulder length. I had to go to a dealer and buy them  :-X  expensive!!!
Hope things work out for you,
Later,
Bill
