limited slip diff
  • 2449 Views
Offline nz_escudo
  • 20
limited slip diff
« on: September 19, 2003, 04:19:48 PM »
I have a 89 escudo (sidekick) I was wondering if any models came out with a factory LSD, if so will it bolt on to my escudo or would mods be needed?
  • 6603
  • 69
Re: limited slip diff
« Reply #1 on: September 21, 2003, 05:40:27 AM »
If you have the 10 bolt carrier for the 7.5 ring gear (which you should have with an '89 model), a factory LSD is available. The only people I know selling them in the US is Calmini. I believe it's a limited slip for a Samurai rear. There may be one, I think there is, for the 12-bolt carrier as well but I'm not sure. Give them a call.
Good Luck, Eric
« Reply #2 on: September 21, 2003, 07:40:16 AM »
I was going to put a LSD in the front
of my kick, but was told that they don't
really work as well as a locker.
I wanted the LSD to allow better turning
than with a locker in the front, but I think
the best solution is an air locker, a bit
pricey, but the best you can get, and
you will not be dissappointed with the
performance.
