NEW PICTURES ON MY WEBSHOTS WEB PAGE
  • 3196 Views
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« on: September 13, 2003, 03:04:03 PM »
SOME PICTURES OF MY 4 DOOR KICK CALMINI STYLE  :o NOW ON MY WEBSHOTS WEB PAGE . ;D HAVE FORD FULL SIZE TIRE & WHEELS ON IT FOR NOW  :'(  .CLICK LINK AT BOTTOM OF POST  8)... MY WIFE NAMES IT OBSESSIVE BEHAVIOR...BUT TRYING TO COME UP WITH A HALLOWEEN NAME AND THEME :-/ ANY THOUGHTS OR SUGGESTIONS?  WAS GONNA GO WITH A GRAVE DIGGER THEME IF I FOUND A BLACK KICK...BUT ITS GREEN  ::) NOT MUCH TO LOOK AT YET BUT ITS ON ITS WAY  :D   HAPPY ZUKING MATTY D.
Offline Agent Orange
  • 711
    • Trying to learn
Re: NEW PICTURES ON MY WEBSHOTS WEB PAGE
« Reply #1 on: September 13, 2003, 05:31:58 PM »
looks good ny, you'll never be the same again.
Offline trackinstile
  • 435
« Reply #2 on: September 13, 2003, 08:08:32 PM »
     Wow, you did a nice job with the lift and wheels, it's a far cry from those white walls ::).  As for a name, you'll think of something.  Something like the Green Ghost or something like that.  Just a thought, and again, your Zuk looks great!                Dave ;D
Offline DSHornet
  • 250
  • Logs and Sidekicks don't mix well at 60 MPH.
« Reply #3 on: September 14, 2003, 01:59:03 AM »
HAVE FORD FULL SIZE TIRE & WHEELS ON IT FOR NOW.
Do the Ford wheels fit with no mods? Are they type JJ wheels? Any interference with the hubs, suspension,  or calipers? How about width, back set or offset? The reason I want to know is that I want to eventually put some larger tires on my '94 JX but I'll have to replace the stock 15X5.5" wheels to do it.
While I'm at it, just what is back set? Offset? Are they the same thing?
Don, y'all
Paw-paw Don, y'all
.Late '94 Sidekick 1.6 ragtop, slightly modified.
Favorite saying: "One need never apologize for exercising the Golden Rule."
« Reply #4 on: September 14, 2003, 05:42:56 PM »
5.5 on 5 - 4 1/4" center opening
wheels will bolt on fine, look for
some older 1/2 ton Fords, they
have this size, I could get these
from the pick a part for $20 ea.
and if you get some half good
tires to run for a while, all the
better.  Most of these wheels
are the "wagon wheel" spoke
looking type, I don't mind but
they look a little old in style.
Back spacing is the distance from
the mounting surface to the bead,
and stock rims have quite a bit so
you should be fine with the Ford
replacements.
  • 2274
« Reply #5 on: September 15, 2003, 11:00:22 AM »
Don, y'all
 NO... I HAVE PUT IN THE CALMINI 6" COMBO LIFT :o...TYPE JJ??? I DON'T KNOW.. THEY WERE SOMETHING BRIAN HAD LAYING AROUND AT THE SPEED SHOP :D. HE SAID THEY CAME OFF A FULL SIZE FORD IS ALL I KNOW  :-/ .HE SWAPPED ME FOR MY STOCK ONES..SO IT WOULDN'T LOOK AS BAD WITH THOSE LITTLE TIRES  ::) HOPEFULLY SOON I WILL UPGRADE TO SOME THING IN THE 31-33" RANGE  :P  HAPPY ZUKING ! MATTY D...
Offline Mac
  • 407
  • Toys, Toys, Toys
    • 1985 Suzuki Samurai
« Reply #6 on: September 15, 2003, 11:40:29 AM »
Looks great, time to go play.
Mac
  • 711
    • Trying to learn
« Reply #7 on: September 15, 2003, 12:55:51 PM »
ny,
i think you should call it the jolly green giant
