BLACK STEELE WHEELS
  • 18 Replies
  • 6932 Views
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
BLACK STEELE WHEELS
« on: August 21, 2003, 11:50:07 AM »
ANYONE KNOW THE CHEAPEST PLACE TO PICK UP 5 BLACK STEELE WHEELS TO FIT A SIDEKICK ???
Re: BLACK STEELE WHEELS
« Reply #1 on: August 21, 2003, 12:56:57 PM »
I got mine for $40 each 8x15 5.5 on 5
from 4 wheel parts . com
take a look.
« Last Edit: August 22, 2003, 05:19:56 AM by ebewley »
  • 2274
« Reply #2 on: August 21, 2003, 01:21:40 PM »
OK THANKS I WILL!!!!!!!
Offline Mr._NSX
  • 155
« Reply #3 on: August 21, 2003, 02:44:03 PM »
Thats where I got mine also, they have free shipping on the weekends, be sure to get the 2.5" backspacing! ;D
Rocky Road also offers custom backspaced wheels in a similar design, but the cost $50 each and who knows how much shipping would be! >:(
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #4 on: August 22, 2003, 02:06:54 AM »
I got mine from a local tire shop (here called Les Schwab) for 33$ a piece.... :)
Heather
Heather Galvin
Offline Somer
  • 143
  • Hey, is it suppose to do that!!
    • D2
« Reply #5 on: August 23, 2003, 02:38:57 AM »
I got mine from Summit for about the same price as everyone else, but I don't think that I will be buying cheap rims anymore.  Who every welded mine together did a really bad job.  They wobble a whole lot because they are not straight.  Any one else ever have this problem?
« Reply #6 on: August 23, 2003, 03:18:44 PM »
Negatory on the bent/crooked lousy weld job, the only reason my
wheel wobbles is a bent axle, I ripped up a 60 pound boulder
doing donuts in a wash down at Tiera Del Sol 2002, also blew
a 7 " gash in the sidewall of my 235x75 15 tires, glad it
wasn't one of the swampers, that would be a terrible
waste of rubber.  :)
Offline Mr._NSX
  • 155
« Reply #7 on: August 23, 2003, 06:02:20 PM »
H
« Last Edit: August 23, 2003, 06:04:16 PM by Mr._NSX »
Offline Mr._NSX
  • 155
« Reply #8 on: August 23, 2003, 06:02:30 PM »
Heather
Yeah, most likely you got car wheels with, umm I'm guessing 3.75" back spacing.  Okay for some, but I'd go with 2.5" bs wheels, less trimming, won't risk(as much) damageing ifs components, and a wider stance. Worth the extra $$ IMO 8).
« Last Edit: August 23, 2003, 06:04:52 PM by Mr._NSX »
  • 2274
« Reply #9 on: August 24, 2003, 02:34:48 PM »
NOW SPEAKING OF WIDER STANCE! DOES ANY ONE RUN THOSE WHEEL SPACERS ??? AND WHAT ARE THE PROS AND CONS OF THEM ??? JUST CURIOUS  ::)
Offline DSHornet
  • 250
  • Logs and Sidekicks don't mix well at 60 MPH.
« Reply #10 on: August 24, 2003, 03:32:41 PM »
'Way back in the olden days I used some thin ones (~ 1/4") on a Plymouth Satellite to keep the wheels from rubbing the upper ball joints. I had no problems, but I checked my wheel nuts every few weeks just to be sure.
Don, y'all
Paw-paw Don, y'all
.Late '94 Sidekick 1.6 ragtop, slightly modified.
Favorite saying: "One need never apologize for exercising the Golden Rule."
« Reply #11 on: August 24, 2003, 09:58:46 PM »
I just put some 1.25" spacers on my X-90 ;D I know it makes it look alot better :o If I have any problems out of it I'll let you know. Right now the only difference is some rubbing on the bumper cover when turning, but that will be fixed this weekend.
Offline Somer
  • 143
    • D2
« Reply #12 on: August 25, 2003, 01:46:28 AM »
I use 1" spacers in the front and I have had no problems yet either, but I only have 4"s of offset on my rims.
jdraper
« Reply #13 on: August 26, 2003, 01:34:16 AM »
If you're talking about the aluminum spacers that just slip over the studs, they have a nasty habit of letting the lugs back out and then damaging the wheels.  There are quality spacers out there (see  spidertrax Calmini, Rocky Road and a bunch of other places carry them too)  that bolt over your existing studs and have their own studs built in.  These work great, but they cost about $100-120 a pair, so if you aren't in love with your current wheels, it's actually cheaper to go with a set of the steel rims.
« Last Edit: August 26, 2003, 02:16:09 AM by ebewley »
Offline LBC4x4
  • 78
  • 1992 4door 3" body 1"coil spacers 31x10.5
« Reply #14 on: August 26, 2003, 11:35:20 AM »
The only problem with the wheel spacers is that if you have a sidekick and you widen the weelbase up fornt it will put more leverage on the sparings and might cause you some camber issues
