TJ Coils
  • 4151 Views
Offline kicker-in-ks
  • 26
TJ Coils
« on: August 17, 2003, 12:35:45 AM »
I noticed that Natebert was running a Calmini two inch lift, but has since switched out his springs. Well, I have a similar '95 wagon, but stock with one inch coil spacers. I was wondering if I did the same, what would I be looking to have to modify, or would I just have to remove the spacers.
Also, I welcome any ideas on how to further modify my lil black rollerskate. So far it's got the Calmini header/cat-back exhaust, K&N air filter, Calmini 3 in body lift, and Rocky Road 1 in coil spacers.
Mike Smith
'95 4-Door Wagon
3in. body lift, 1in. coil spacers, 29" Swampers
Offline Natebert
  • 1098
Re: TJ Coils
« Reply #1 on: August 19, 2003, 07:40:29 AM »
Are you running spring spacers front and rear?
I wouldn't see any problems just running the rear TJ coils in the back.  You might have a heck of a rake though.
  • 26
Re: TJ Coils
« Reply #2 on: August 19, 2003, 08:52:51 AM »
Natebert,
Yes, I am running coil spacers both front and rear. The rake you are talking about, is that from running tj coils and spacers, or just the springs themselves. If I can run those springs without modification, I have no problem removing the spacers in the rear to reduce rake.
Mike Smith
'95 4-Door Wagon
Offline Natebert
  • 1098
Re: TJ Coils
« Reply #3 on: August 19, 2003, 12:25:02 PM »
We are running the TJ coils just in the rear.  No spacers anywhere.  The TJ coil springs were nearly a perfect fit.  Only the bottom coil needed to be closed a bit (for a more accurate fit).
The front springs on our rig, are some custom fit springs to help level the extra lift the TJs provided over the 2 inch Calmini lift in the rear.  (The 2 inch Calmini lift uses the stock prings in the front)  So we don't have ANY Calmini springs in the setup.  Just the A-Arms, diff drop brackets and struts.
Good luck!
  • 26
Re: TJ Coils
« Reply #4 on: August 19, 2003, 01:48:55 PM »
Thanks for all of your help. It helps me out quite a bit. ;D
Mike Smith
'95 4-Door Wagon
Offline 1bigtracker
  • 3409
Re: TJ Coils
« Reply #5 on: August 22, 2003, 08:56:11 AM »
ummm sorry if this sounds stupid but umm what is rake?  did i miss somthing?  sorry for bein a rookie
Offline hcgalvin
  • 1695
    • Granite Path
Re: TJ Coils
« Reply #6 on: August 22, 2003, 09:03:08 AM »
A rake is when either your front sits higher than your rear (backward rake.. something you don't want) or your rear sits higher than your front (forward rake). Sometimes a little forward rake is good, because when you are loaded up in the back or have passengers, your truck may sit level.  ;) A little forward rake can sometimes help aerodynamically too... a lot of race cars have a forward rake. But too much, can look really funny.  :o
Heather
Heather Galvin
