How is this for a start????
  • 3050 Views
Offline Mr._NSX
  • 155
« on: August 06, 2003, 06:20:51 PM »
Okay, I just fininshed installing the bodylift (Calmini 3in) and am going to  get OME coils front and rear 1.5" lift and fit some 31in tires on daytona 2in custom backspaced rims.
Now to my questions, will I need to upgrad the struts and shocks while using the ome springs?  Also will it be a good idea to add some coil spacers to the front and rear.  My plan is to wheel this setup and save/wait for the Calmini sas.
My other option would be to buy the 2in calmini lift, will the above ome springs and spacers perform as well as the calmini 2in lift, as far as articulation?
thanks
Offline LBC4x4
  • 78
  • 1992 4door 3" body 1"coil spacers 31x10.5
Re: How is this for a start????
« Reply #1 on: August 07, 2003, 02:56:11 AM »
I have the 3 in body lift and 31x10.5 on 2.5 back spaced wheels and due to the added leverage from the back spacing of the wheels The front sagged alot and I had to buy coil spacers in the front just to help out the camber issue. Its still saggs a little but not enough to worry about.
