Interior roll cage??
  • 18 Replies
  • 5561 Views
Offline Not_Stock
  • 15
« on: August 03, 2003, 10:01:47 AM »
Which one do you have?Where did you get it?Is it a off the shelf or custom or modded off shelf?One is on my list of mods for my Tracker so I'm doing some research!!! TIA
1994 Geo Tracker:Modified 6" lift and 33's coming soon!!
Offline suzuki1750
Re: Interior roll cage??
« Reply #1 on: August 03, 2003, 12:56:15 PM »
I have some pics of mine. I built it from scratch. Never built one for a kick tho. Altho it should be fairly easy.
you can see mine at.
http://community.webshots.com/user/suzuki1750
Steve Schilling
Barnhart, Mo.
90 Samurai
Locked, Lifted, Geared, "Porterized", rear springs up front, Custom missing links, Custom bumpers, Warn M8000, RS9000's, Custom 6 point cage.
suzuki1750|removethispart|@cs.com
izook . com
« Last Edit: August 04, 2003, 01:51:05 AM by ebewley »
Steve Schilling
Barnhart, Mo.
90 Samurai
Offline Mr._NSX
  • 155
« Reply #2 on: August 03, 2003, 01:05:35 PM »
Steve Schilling
Barnhart, Mo.
90 Samurai
www.izook.com
What did you use to bend the tubing? Did you use DOM tubing of something else.  Thinking of buying a tubing bender but need some reason to justify the $.
Thanks.
BTW Eric won't like the izook link.  I found that out the hard way, oh well :-[
« Reply #3 on: August 03, 2003, 11:48:38 PM »
I had mine built due to my very limited welding ability.
If you build your own or have someond custom build one, be sure that you (or they) know how to build one and can weld VERY good. After seeing a member of my former 4x4 club roll, and on the second time on the roof a sperader bar's weld broke, sending the end of the bar completely through his wifes belly, I'll never have any one but a pro weld on my vehicle again. If we did not have an ER surgon on the ride, and a place to land the helicopter, she would of died that day.
If you ride extreme dont skimp on a cage, it could kill somebody!!!!!!!!
Offline 1bigtracker
  • 3409
« Reply #4 on: August 04, 2003, 03:37:48 AM »
I haven't done this yet but one of my friends said to buy a cage kit for a car out of JEGS and mod it to fit the Tracker.  He said all the cutting and notching would be vary laboring,  and he sould know.  he has built 3 mud drag trucks and 2 street drag cars.
Offline suzuki1750
« Reply #5 on: August 04, 2003, 04:20:04 AM »
I used a ez tube bender from toolsplus1.com.  It came with four dies and a follow bar. It will easily bend DOM. Altho my cage is built from ERW 1.75" .120 wall tubing.
As for the izook link, I didnt know suzuki bbs were in competition with each other. I subscribe to all suzuki lists.
Steve
Steve Schilling
Barnhart, Mo.
90 Samurai
Offline FNG
  • 197
  • 91 TRACKER 6" LIFT ON 34S, SKID PLATES AND CAGE
« Reply #6 on: January 30, 2006, 12:38:24 PM »
I USED THE CAGE FROM CALMINI.ALL YOU HAVE TO DO IS FIT,NOTCH AND WELD.NO BENDING
NEEDED.
Offline elotsip
  • 42
« Reply #7 on: January 30, 2006, 06:33:15 PM »
Will the calmini kit  fit in a 4dr or 2dr only?
« Reply #8 on: January 30, 2006, 11:19:28 PM »
Only a 2dr. The bars running foward would be too short.
The rollbar only and rear down tubes would fit (4pt kit)
I thought about getting one and extendung it alittle to fit my 4dr.
But then the seats won't recline  :-\
Offline toolman21
  • 229
« Reply #9 on: January 31, 2006, 01:27:38 PM »
A friend of mine builds rollcages for drag cars.  The main thing is it is not for looks, it is for safety, you want to make sure it will work when you need it...which I hope doesn't happen.
Toolman
« Reply #10 on: January 31, 2006, 09:21:35 PM »
So true my friend.
If you take the headliner out of a 4dr.
There is only one roof cross bar and that just holds the dome light up.
I had a Race shop want to build me a custom Rollcage for the 2dr.
It was going to be an all out RollCage.
6 point adn lots of crossbracing.
Probley wieght 200lbs and cost a $1,000 bucks.
Cross bracing is the Key to strength.
But it would hold up in a 200mph crash.
Wish I could get it over 90mph (downhill of course)
Not that I would ever speed.
« Reply #11 on: February 02, 2006, 05:05:05 AM »
I once drove a Track/Kick/Vit that had an internal cage. If you're tall make sure its well padded, there isn't a lot of space around your head when you get the cage in there.
bump, ouch, bump, ouch etc......... ::)
« Reply #12 on: February 02, 2006, 05:33:51 PM »
And thats why I HAD to find Padding
Offline elotsip
  • 42
« Reply #13 on: February 07, 2006, 02:30:35 PM »
Hotrod, did you build that cage yourself? Looks great.
« Reply #14 on: February 07, 2006, 10:59:54 PM »
giving vcredit where credit is due.
Nope, thats the Calmini one.
A race shop said it would be cheaper to buy theirs(Calmini) to get all the right bends.
Saves a lot in labor.
Then find a luckie person to weld it  in.
Took 4 hours  ;) ;D
