custom body lifts?
  • 12 Replies
  • 8845 Views
Offline track_this
  • 332
custom body lifts?
« on: July 24, 2003, 10:37:09 AM »
trying to get some ideas on a body lift and was wondering if anybody could help me out, what you used and how. thanks for the ideas.
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
Offline Mr._NSX
  • 155
Re: custom body lifts?
« Reply #1 on: July 24, 2003, 11:33:20 AM »
I just scored a calmini body lift off of ebay for $100 shipped, its new in package.  Sorry if this dosn't help but I will take pics of the installiation and of the calmini product, maybe this will help you understand how the calmini lift works (if you don't already) and maybe it will spark some ideas on possiable design.
Hope this helps,
Aaron
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
« Reply #2 on: July 24, 2003, 03:46:11 PM »
Y run good f*cking old 3"x3"x3" steel square tube!!!!!
drill a hole in the center of 2 sides and bolt the bottom to frame with grade 8 hardwares and rebolt stock rubber bushings and bolts to the top of the tube.
You have now an 3.5" body-lift.
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Offline track_this
  • 332
« Reply #3 on: July 25, 2003, 10:16:45 AM »
did you do any work to the shifters or steering? and how could you bolt the tube to the front body mounts. any lines or wires that i should know about before hey get pulled. thanks alot.  shane
rear lockright
31" kumho m/t's
Offline Fredo
  • 416
« Reply #4 on: July 25, 2003, 04:37:31 PM »
For the front just bolt the tube to de body and stock rubber and bolts to the bottom of the block.
I cut ,extend and weld the shifters and the steering shaft.
I drop the front driver side brake line.
Extant the gaz hose too...
Fredo
Offline track_this
  • 332
« Reply #5 on: July 28, 2003, 05:58:01 AM »
do know of anybody that has a website with some pics of the steering shaft or just some pics of what i need for the steering? the drivers side brake line is it easy to relocate lower or am i going to have to buy new line and just route my own path? ive got all the 3" tubes cut and drilled just figuring out the rest of it.  thanks for your help.
shane
rear lockright
31" kumho m/t's
Offline Fredo
  • 416
« Reply #6 on: July 28, 2003, 08:17:02 AM »
The front break line are very easy to relocate...
Just to unscrew the rubber break line to the hard break line in the fender.
Drill a hole in the fendre(lower as possible).
Rebolt the stock break line to the hard line in the new hole and voilà!
Fredo
Offline track_this
  • 332
« Reply #7 on: July 29, 2003, 03:01:34 PM »
thanks fredo!
 i got a guy lined up to weld an extension on to my steering and shifters. the same guy works at a machine shop so he said he make me some custom strut spacers so here i come 33's(i have a date with the sawzall and the fenders though) but i dont care its all about the tire.
shane
rear lockright
31" kumho m/t's
Offline 1bigtracker
  • 3409
« Reply #8 on: July 30, 2003, 03:37:14 PM »
the calmini kit was REALLY cheap.  if u had some hockey pucks and 2X2 tubing u could do it in you garage.  if u want i will give u a list of everything that comes in the kit just email me.  I used a socket as the steering shaft extention.
« Last Edit: July 30, 2003, 03:39:59 PM by 1bigtracker »
Offline Natebert
  • 1098
« Reply #9 on: July 31, 2003, 09:43:55 AM »
...awesome
Offline Mr._NSX
  • 155
« Reply #10 on: July 31, 2003, 11:20:35 AM »
Fredo
How do you get 3.5in of lift if you use 3" tube??  Where does the extra 1/2" come from?
Just courious. ;)
Offline pbgbottle
  • 76
« Reply #11 on: July 31, 2003, 03:38:52 PM »
as for the steerin shaft i just make a spacer and used longer bolts   see pic any feed back would be great
http://www.cardomain.com/member_pages/view_page.pl?page_id=388302&page=2
sorry about bad pic                         Jake
1997 suzuki sidekick
4dr. auto
Calmini 6 inch
31x10.5 yokohamas on american racing 15x7
see the machine at http://www.cardomain.com/id/pbgbottle
Offline Fredo
  • 416
« Reply #12 on: July 31, 2003, 06:51:13 PM »
the 3.5" body-lift with 3" blocks is du to the curves of the stock location for the ribber mount and some bi washers hehe!
