need to pass DEQ in Portland, OR
  • 12 Replies
  • 4862 Views
Offline fowellkris
  • 14
« on: April 25, 2005, 07:24:19 AM »
just picked up a 1986 Sami. i have replaced plugs, oil pan gasket, oil change, filter, air filter, currently running seaform through gas and then changing fuel filter, have new wires. I have sprayed the carb with cleaners, the gas is high thru the window on the carb so i will probably need to adjust float. I was told first time thru emissions that i am not burning all of my gas. running rich? am i missing something or is just a matter letting all the cleaners do their job. this sami was sitting for almost two years. help please as this is my new daily driver. seems to run fine
Offline Moallen
  • 68
Re: need to pass DEQ in Portland, OR
« Reply #1 on: April 25, 2005, 07:46:37 AM »
Move to Missouri , we don't have that government Liberal crap:)
1987 Samurai 32" front and rear lockers 1.6 engine spring over lift 512 gears
2005 dodge dually 4x4 diesel
98 Jeep
1989 34' Stamas twin 225
20' Sea Ark boat 1989 toyota (beater car)  two cobra kayaks 28ft classic car haul kubota L2900 tractor
  • 6598
  • 68
« Reply #2 on: April 25, 2005, 07:58:07 AM »
....gas is high thru the window on the carb so i will probably need to adjust float. ...
This part concerns me. There isn't a sight glass on stock 86 Samurai carburators. Try doing a search on carburators here. I know there is a thread or two with pictures of a stock carb.
« Last Edit: April 25, 2005, 07:58:24 AM by ebewley »
Offline fowellkris
  • 14
« Reply #3 on: April 25, 2005, 09:11:12 AM »
there is a sight glass on mine. i was guessing that it was original. the point though is what ideas does anyone have for me to pass emissions
Offline SnoFalls
  • 1358
« Reply #4 on: April 25, 2005, 09:42:31 AM »
could try the timing ... sometimes older engines (where compression has dropped) benefit from more advance than "book" value.
It's something you can adjust on the pad, and the tester *might* let you know the difference timing changes it.
Offline Natebert
  • 1098
« Reply #5 on: April 26, 2005, 07:18:15 AM »
Try installing a good catalytic converter.
~Nate
Offline fowellkris
  • 14
« Reply #6 on: April 26, 2005, 10:58:00 AM »
if it needs a cat will universal work or should i get ahold of petroworks, etc.
Offline dubl_t
  • 8
« Reply #7 on: April 26, 2005, 06:18:42 PM »
just get a cheepy cat, you'll prbly remove it later.  You might try mixing in a little "white gas" or Coleman fuel in your tank, I've heard it works but haven't tried it.
Nothin like spotted owl roasted over old growth fir!
Offline Natebert
  • 1098
« Reply #8 on: April 27, 2005, 05:40:13 AM »
Sure! Universals would work, might be able to find a high-flow cat too.
Offline fowellkris
  • 14
« Reply #9 on: April 27, 2005, 05:49:10 AM »
does the cat have to be welded in or can it be done as a slip joint with the U-bolts?
Offline Natebert
  • 1098
« Reply #10 on: April 27, 2005, 08:45:02 AM »
I don't know specific Oregon rules, but in Idaho, I believe that they have to be welded in.
Offline fowellkris
  • 14
« Reply #11 on: April 27, 2005, 11:42:01 AM »
just tried again and got closer to passing. after running seafoam and changing the fuel filter, the plug wires,  a thorough cleaning of the EGR valve and tried to clean the intake side without removing the intake.  i passed HC with a 3.74 and brought my CO down to 114.0 but i need to get to 85.0 or better. If it were running rich would it cause this to happen? thanks
Offline breadbox
  • 119
  • Me Like Doughnuts!!
« Reply #12 on: April 27, 2005, 06:11:39 PM »
Try putting in a bottle or two of rubbing alcohol, I had a friend who put two of the smaller bottles in on a 1/4 tank and it passed after failing badly the first time.  It worked for Washington emissions.   ;D
1.3 ltrs of FURRY!!!!!!
