Who makes Strut Spacers for the Kick?
  • 16 Replies
  • 7572 Views
Offline adamd
  • 369
  • sofa king we todd it
« on: April 25, 2005, 03:06:28 AM »
Been looking but can't find any... I suppose 1 inch is enough for the 1.5" coil spacers I want to put.
Thanks
'98 kick
3" B/l
30" Mud Kings
Re: Who makes Strut Spacers for the Kick?
« Reply #1 on: April 25, 2005, 03:29:26 AM »
For that ammount you can flip the upper strut mount. There is a recent thread showing details of how to do the flip. As far as I know the only ones around come with the Calmini lift kits and are not sold seperate. There are a few people that have made their own though.
Offline adamd
  • 369
« Reply #2 on: April 25, 2005, 05:24:37 AM »
Yeah I read that, I guess I'll just do the flip. I wanted a little more than 3/4" drop though. But I guess it'll do.
'98 kick
3" B/l
30" Mud Kings
« Reply #3 on: April 25, 2005, 05:38:58 AM »
Do a search on struts. The Old Man Emu Strut is a bit longer than the factory. Just watch allowing it to drop to far. If you barely push it to far, you will start over extending the CV's and can break them easier.
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #4 on: April 25, 2005, 09:15:42 AM »
I have made strut spacers but I have yet to find anyone selling them.   Everyone says not enough interest...
« Reply #5 on: April 25, 2005, 09:18:35 AM »
Try Procomp. I have heard that Procomp UK sell strut spacers or Deldana in Brazil (do a search on here for a link). Their website is all foreign language but they answer emails in english
Offline adamd
  • 369
« Reply #6 on: April 25, 2005, 09:29:51 AM »
I guess I could always flip the strut mount it and space it out with a few pieces of tin. I don't have a fancy plasma cutter, and my drill sucks ;)
'98 kick
3" B/l
30" Mud Kings
« Reply #7 on: April 25, 2005, 10:18:18 AM »
If you could get hold of some 1/2" plate or similar and some longer bolts theres no reason why you couldn't do the strut flip and space it a bit. If you look at the Calmini 2" kit that relies on the strut flip for extra front travel there are two thin spacers/shims that fit inside the strut mount to 'fill' it so the pressed edge isn't against the bodywork (thats a really rubbish explanation but I have been drinking  ;)). As long as it sits square the finish isn't critical you could chain drill and file it to shape - I have made lots of parts that way in the past.
Offline Cwkick
  • 888
« Reply #8 on: April 25, 2005, 10:20:24 AM »
Header collectors off of a small block Cheby, Ford, whatever, work as spacers also.  That is pretty much what Calmini sends you for a spacer.
Cwkick
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #9 on: April 25, 2005, 11:21:39 AM »
I have 3/4 and 1" allum. strut spacers avalible if flipping the mount is not enough for your app. like zig said to much droop and cvs will start to blow out. :'(
Offline Jookycola
  • 372
« Reply #10 on: April 25, 2005, 05:24:04 PM »
Cwkick....how much lift does your kick have?  it's a small picture, but it looks lifted.  i'm trying to find a good picture of a track kick with 2 or 3 inches of lift....on flat ground so i can get an idea of how the trackkick's stance is.
  [/url]
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« Reply #11 on: April 25, 2005, 05:38:50 PM »
my lifted vitara.
i can post more pics if you like, or if you want a certain pic of anything.
and the strut spacer i made.
i wont be using the strut spacers anymore, as this was the absolute max you can go before you get chronic CV problems. my strut spacers were 2" and used on top of the factory suzuki struts. DO NOT FLIP THE STRUT MOUNT with 1.5"+ spacers fitted. doesn not work.
i am getting OME struts, which have 40mm longer stroke then the stock suzuki one, and i will run this with a strut mount flip. in theory,it works out to be the same as a 2" strut spacer and standard struts.
where i am, there isnt much rock or hard terrain to drive on, its mainly loose stuff, and or mud. so my CVs have held up ok, and driving style is directly related to failure of CVs.
Offline Cwkick
  • 888
« Reply #12 on: April 26, 2005, 03:25:44 AM »
It has a Calmini 2" lift on it.  If you look through the article archives there is an article called On Higher Ground.
It is all about the install of this lift.
Is is a bigger picture that Zig took when he stopped to visit me on his way to Moab.   8)
Cwkick
« Last Edit: April 26, 2005, 03:26:22 AM by Cwkick »
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #13 on: April 26, 2005, 05:30:43 PM »
Here's a shot of my Tracker sitting on 1" coil spacers and a 2" body lift with 31" Swampers(for the guy that wanted to see a Track/kick sitting on 2-3" of lift on level ground):
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #14 on: April 26, 2005, 07:01:55 PM »
i got my lift kit from bds suspension - they use a thread on extension for the top of the strut - 2 inches long and i think they are available separatly from the lift kit
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
