clutch
  • 2423 Views
Offline randy
  • 6
clutch
« on: April 24, 2005, 03:08:43 AM »
I just bought a sammy for $200 and got it sarted in about 8-hours. can't put it in gear when it is runing.somone said that this could be the slave cyclinder.also how do you put the 4x4 shifter in, thought i new how but don't want to mess anything up.
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
Re: clutch
« Reply #1 on: April 24, 2005, 03:29:33 AM »
there is not a slave cylider. it is a cable clutch check and make sure the cable is conected and tight it may also be broken inside some where. the t-case if u just bought the sami order a set of pins and a new sheeth from hawk just as a precaution sence the shifter is already out and buy a manuel it is worth its wieght in gold.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline randy
  • 6
Re: clutch
« Reply #2 on: April 24, 2005, 04:34:17 AM »
tried to tighen the cable but the line keeps twisting around as am tying to tighten it.
Offline Chief
  • 678
  • Whaddya lookin at??
Re: clutch
« Reply #3 on: April 24, 2005, 05:12:42 AM »
Get a manual from an auto parts store. It'll walk you thru the right way to do it.
Offline randy
  • 6
Re: clutch
« Reply #4 on: April 24, 2005, 11:57:09 AM »
finally got the cable to tighten up now how do you put the 4x4 shifter in.
Offline Natebert
  • 1098
Re: clutch
« Reply #5 on: April 25, 2005, 03:54:48 AM »
I'd make sure the forks in the t-case are lined up and drop it in,
Push the keeper down and give'er a twist.
~Nate
Offline HUMZUKI
  • 117
  • Fool!
Re: clutch
« Reply #6 on: April 25, 2005, 07:18:26 AM »
Make sure the shifter sheet is good. Do a search on the Lowes shifter sheet. I forget the part number but its only $1.30 or something. And works fine. most likely Its shot if there even is one. Your going to be pissed if you get it back together withpout it b/c It wont shift.
Offline randy
  • 6
Re: clutch
« Reply #7 on: April 25, 2005, 07:28:01 AM »
well know i got it were the clutch works but you can't change to another gear when your driving.you can put it in 1'st push the clutch in and then crank it and drive around in whatever gear you put it in before you crunk it up.
