Body Lifts
  • 6 Replies
  • 2620 Views
Offline blacknight
  • 987
    • Gonzookin
Body Lifts
« on: April 18, 2005, 07:54:01 AM »
How much body lift is too much.  I know this is a very opinionated thing.  Here's why I was thing about doing a 3 1/2" bd lift and just wanted to get some in put. My options are limted for my XL-7 it ether a 2" RRO kit (which by the way is not for sale yet) or make one my self which would have to 3.5" box tube to be able to bolt it on.
George
« Last Edit: April 18, 2005, 07:54:39 AM by blacknight »
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
Re: Body Lifts
« Reply #1 on: April 18, 2005, 08:41:36 AM »
The shifters are the biggest problem. 3 1/2 is a lot to fit a shifter through the hole. I had 3 inch square tube and it worked fine but the shifters were a pain.
Mike
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: Body Lifts
« Reply #2 on: April 18, 2005, 10:02:19 AM »
I think on a XL-7 (like a GV) the steering would be the biggest problem because of the system it's very hard to lengthen the shaft. After that the shifters would be a problem, but I'm not a GV expert  ::)
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline Nemesis_y2k
  • Slowly but surely.
    • The Tree Stump
Re: Body Lifts
« Reply #3 on: April 19, 2005, 05:15:59 AM »
I and my buddy both have 4 1/4 and we can shift fine, no grinding was required for the shifter area.
Offline sergi
  • 307
Re: Body Lifts
« Reply #4 on: April 19, 2005, 05:22:18 AM »
4 1/4 is quite a lot. What model do you have?
At least in my GV, a 2" lift will probably need some plastic coming off to allow the gearbox shifter to move proerly. Maybe the transfer shifter too. ::)
Suzuki Grand Vitara 3dr TurboDiesel
Barcelona, Europe
Aquesta és la meva màquina. Creus que em pots seguir?
Offline blacknight
  • 987
    • Gonzookin
Re: Body Lifts
« Reply #5 on: April 19, 2005, 11:09:58 AM »
Nomad did a 2" bd lift on an Xl-7 the only shifter issues he had was the rubber boot as he did not extend the shifter.
So from I've read so far 3.5"  wouldn't too much except the steering and shifter?
George
Offline Natebert
  • 1098
Re: Body Lifts
« Reply #6 on: April 20, 2005, 07:43:20 AM »
George
Depends on how much stuff you want to modify
