Hard starts when hot
  • 2456 Views
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« on: April 14, 2005, 03:29:13 PM »
My sisters 93 8 valve tracker starts great when its cold but when its hot it takes several cranks to fire. But then it runs great. Any Ideas?
Mike
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: Hard starts when hot
« Reply #1 on: April 14, 2005, 04:31:17 PM »
Hmmm... possibly clogged gas tank vent lines causing a vapor lock situation, bad engine ground connection, dirty air filter or possibly a defective pick up coil in the distributor...
« Reply #2 on: April 14, 2005, 05:46:52 PM »
could be your tps or your touching the gas pedal while cranking.
« Reply #3 on: April 14, 2005, 06:59:28 PM »
Does it smell flooded or rich
when it fires up ???
Bad coolant temp sender or
intake air temp sender could
be telling the computer the engine
is cold, and needs more fuel
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #4 on: April 15, 2005, 07:31:12 PM »
Thanks for the tips. Im gonna look at it in the morning.
Mike
« Reply #5 on: April 16, 2005, 09:54:42 AM »
Bad Throttle Opener VSV vacuum maybe??
