1.6 engine mounts
  • 3382 Views
Offline mudbug
  • Mudbugging
1.6 engine mounts
« on: April 11, 2005, 10:58:36 AM »
What engine mounts do I need to use to put the 1.6 in a Sammy?
Can I use the original ones in the Sammy?
Can I cut the ones out of the donor vehicle and weld them to the Sammy frame?
Is it best to get the mounts from a manufacturer (i.e. Petroworks)?
Jeeps are for people who can't handle a Suzuki!!!
Offline mudbug
  • Mudbugging
Re: 1.6 engine mounts
« Reply #1 on: April 15, 2005, 07:51:46 AM »
HELP!!!!!
I have not done this before and want to know all that I can before I run into any problems.
I have the engine out of the donor vehicle and am getting ready to clean it up for the install.
Offline nitromax
  • 206
  • FunZilla's alive !
    • NitroMax's Pages
« Reply #2 on: April 15, 2005, 08:37:04 AM »
It was done on my Sammi with the original enginemounts, just the right one had to be re-drilled, that's all !
Info on the swap:
http://www.nitromax.nl/SAMENGINESWAP.HTM
1600 cc 8v, MegaSquirt EFI, Camden SuperCharger, Calmini 3" Shackle Reversal, IronMan 3"suspension lift, SPOA and 2"bodylift, 4.16 T-case, QuickLok rear, 33x12.5 ProComp XT's on 8"rims with 1"wheelspacers.
Check it all on : www.nitromax.nl
International editor |removethispart|@ www.izook.com
Offline mudbug
  • Mudbugging
« Reply #3 on: April 15, 2005, 11:11:08 AM »
Do you think that I will have to change the oil pan if I have already put the Calmini Shackle reverse on, it is lifted 2 inches above stock height.  I think that I am going to get the Rocky Road adapter plate and engine mount relocators?
Offline nitromax
  • 206
    • NitroMax's Pages
« Reply #4 on: April 15, 2005, 06:16:32 PM »
To be honest, I also have the Calmini SR ( 3" on mine ) but didn't check if the oilpanchange was really needed, just went ahead and did it anyway.
« Last Edit: April 15, 2005, 06:17:12 PM by nitromax »
Offline LawDog
  • 531
    • Emerling Chevrolet
« Reply #5 on: April 16, 2005, 01:46:46 AM »
When we did my Sammi, i beleive the pass. side mount can be reused from the Sammi and you can combine the motor end from the donor car w/the Zuk end of the Sammi mount on the driver side.  If you have access to a welder that is.  I'll post some pics if I get the chance, but it might be a while, the LawDog is over at RealRedSammi's house with a bum clutch right now.
« Last Edit: April 16, 2005, 01:47:57 AM by lawdog »
