toyota axles and sidkick axles?
  • 2229 Views
Offline BEETLE-TRIZ
  • 17
« on: April 14, 2005, 02:45:23 AM »
ive got an old toyota truck imthinking 78-79 its got the rounded bubls flares if that helps anyone? its got 5.13 gears in it  i have been told that the bolt right into my sidekick is that true and are they stronger like axle wise then wut i got  from factory ?
Offline chet
  • 556
  • Zuki time!
Re: toyota axles and sidkick axles?
« Reply #1 on: April 14, 2005, 03:24:03 AM »
first off if it has lower gears it will have 5.29's as toyotas aren't available with 5.13's
for these to fit they will need alot of fabrication. You rear end is coils the toy is leaves. Your front is IFS the solid toy front is leaves as well.
Not saying it can't be done but you will have to figure out steering, brakes, driveshafts, leaf spring mounts, shock mounts, different rims as they are different bolt pattern.
Offline BEETLE-TRIZ
  • 17
« Reply #2 on: April 14, 2005, 03:44:27 AM »
will the gears inside of the toyota axle fit inside my housing?
« Reply #3 on: April 14, 2005, 03:58:22 AM »
No, a Toyota and a Suzuki have different gears.
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #4 on: April 14, 2005, 04:50:47 AM »
do u have a standard or an auto. if u have standard u have 5.12 gears. u need to go to the article arcives on the front page they r very informative and can answer alot of questions before u ask them and they will give u some questions to ask. have fun reading. oh the only thing that will swap inyo a sidekick is a tracker set up because they r the same thing. GOOD LUCK.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline BEETLE-TRIZ
  • 17
« Reply #5 on: April 15, 2005, 02:46:29 AM »
my 89 kick is automatic  was there just a set gear for that truck tht year or was it different gears for  different truck  its the lx series i belive if it was just a set of gears for that truck do u know wut gears they are?
